Dqt gearbox on 3b problems
  • dich
    • Apr 2010
    • 52
    • Country: Bulgaria
    Hi, there guys. I have swapped DQT diesel 6 speed gearbox. I use stock 3b flywheel and stage 5 Spec clutch kit. The problem is that I cant disengage clutch. Do I have to extend clutch cylinder arm and how much? What can be the problem?
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    Gearbox input shaft might be to long.Clutch operates but the shaft is friction turned.Got this hapened on one rs2 gearbox replacement to a diesel one.Do not ask me the diesel code,was some time ago.
    Have a look first into clutch housing by remooving rpm and crank position sensor bracket.Maybe you will get enough space to see if the disc gets free when clutch is pressed.
    • _ShurikeN
      • Mar 2010
      • 733
      • Country: Russian Federation
      Stock 3B flywheel from audi 200 I suppose? It was designed for 016 transmission with long shaft. It is not promised to suit 01A/01E tranny (including DQT).
      • dich
        • Apr 2010
        • 52
        • Country: Bulgaria
        Before this it was running ok with sachs racing pressure plate for AAN with 3b flywheel from s2. This evening i tried with longer(longest possible) shaft on clutch pump. Now it disengages but not fully. When i put into 1st gear with clutch pedal pressed, car starts to move slowly forward.
