Recently my S4 developed a pretty horrible grinding noise (with a slight drone to it), it is not properly droning so I'm sure it isn't a wheel bearing and also there is no movement in the wheel. Noise is most prominent at around 30mph and just over 60mph, I really don't dare going over that because it gets pretty scary, very noisy and car starts to vibrate through the steering wheel and pedals. There doesn't seem to be any excessive play in the driveshafts. Slight inwards/outwards movement. Noise doesn't go away/ change when clutch is depressed so hopefully gearbox is ok.
Noise did start after going over the raised bit in the middle of mini roundabout at speed, maybe coincidence, I don't know! Before I start stripping maybe people have ideas on where to start or what to check first?
