s4 wheels
  • stevieyid
    • Apr 2005
    • 2251
    s4 wheels
    Hi im possibly going to buy some s4 17'' avus wheels. I no i would need spacers to fit these anybody bo what size and where i can get them from and a cost for spacers. Cheers
  • martinjs
    • 3205
    trackstore.co.uk should have spacers. Those wheels are et45 so i guess you'd need 10mm ones.
    • 90quattrocoupe
      • Nov 2003
      • 771
      Indeed the ET on S4 wheels is 45. The stock ET for a coupe is 37. I ran 8mm HR spacers with a lip. The lip is a little extension on the spacer. Makes the mounting of the wheels a little easier. I was running a 225/45X17 tire and had no clearance problems at all.
      Greg W.
        Aye 10mm spacers will do the job nicely. 8mm would do but as you increase wheel size it's wise to reduce the ET at the same time.
        • 90quattrocoupe
          • Nov 2003
          • 771
          why?
          Greg W.
            Originally posted by 90quattrocoupe
            why?
            Greg W.
            Typically becuase you when you increase wheel size the width of the wheel also increases over the stock wheel, therefore moving the wheel closer to the steering arms.
            Reducing the ET negates the increase in width.
            • 90quattrocoupe
              • Nov 2003
              • 771
              I can understand that, but I have not found in doing wheel changes that this is not necessarily the case.
              My coupe started with a 7X15 ET37 wheel with 205/60 tire.
              First up grade was a TSW EVOs 7.5X16 ET40 with a 225/50 tire.
              After hub change, S4 Wheels 7.5X17 ET45 with 8mm spacer, making ET37 with 225/45 tire.
              Current wheel is S6 8X17 ET35 with 255/40 tire.
              All of these wheels have been within 2-3mm of the original ET and none of the tires have rubbed on the tie rod arm.
              Greg W.
                Greg W.
                Each to their own but then your not running an S2!
                It's no coincidence that when people have gone to 19" alloys the ET has had to be ET30
                In my case with 18" i'm running ET33 and some others are running ET28 on the same rums.
                • 90quattrocoupe
                  • Nov 2003
                  • 771
                  Gee, I am sorry if I upset you.
                  Let's see. 20V coupe vs S2.
                  Same fenders.
                  Same fender liners.
                  Same steering rack.
                  Same Struts.
                  Same hub carriers.
                  Same tie rods.
                  Same hub dimensions. 4x108 vs 5x112 but the dimensions are the same.
                  Same brakes.
                  Gee I guess all the stuff that affects wheels on the car are different.
                  I was just trying to pass on information to someone who asked about S4 wheels. I used those examples, because I had actually run them on my car. This told me what would rub and what would not. I was passing that along.
                  He didn't mention 18s or 19s, just S4 wheels. I don't have any experience with those size wheels, as I have never fitted them to my car. I only mentioned ones I had fitted.
                  Greg W.
                  • stevieyid
                    • Apr 2005
                    • 2251
                    Can someone tell me if i would need spacers for the s4 avus wheels? According to this thread i do but after looking on the alloy guide that says the s4 avus wheels are 5x112 and et35 is this correct?
                    • stevieyid
                      • Apr 2005
                      • 2251
                      heres the link: http://www.alloyguide.co.uk/Audi.htm
                      • T2Andy
                        • 1903
                        Steve according to that list S8 wheels are 37 mine are deff 48 i had to use 15mm spaces
                        S4 wheels are 45et i know this as i was going to get some before i saw the light
                        get the s6 wheel these are et 37 and look the same.
                        • stevieyid
                          • Apr 2005
                          • 2251
                          problem is mate i have got a very, very good deal on some s4's. How much are spacers? do u no where i can get spacers?
                          • T2Andy
                            • 1903
                            got mine off these guys,
                            http://cgi.ebay.co.uk/15mm-Ford-Whee...ayphotohosting
                            • stevieyid
                              • Apr 2005
                              • 2251
                              Just had a look on this web site for some spacers:http://www.performancefx.net/wsaudi.htm The only 5x112 stud pattern spacers does not have the s2 listed but they should be ok am i correct? Also im a bit confused as to whether i can run the normal bolts with these. Has anyone put s4 wheels on there s2? Cheers
