Can any body tell me if its ok to run a different make of tyre on the front than on the back i.e on different axles but of the same size.The car in question is a s6 quattro
different tyres
As long as they are rated properly, this poses no problem whatsoever.
Unless you wanted to put crossplies on one end it's fine!!
In fact, it's ok on the same axle too, but I wouldn't advise running a mix of different makes of tyre the same axle. It won't get you into trouble.
__MDC__Martin Cutting
It's not better than sex, but it runs it a close second. -
It is actually illegal to have two different tyre treads on the same axle. I know because my Roozer mates pointed it out to me incase i got pulled over about it on my old car.Originally posted by Keeper of The KittenAs long as they are rated properly, this poses no problem whatsoever.
__MDC__Comment
I didn't realise it was actually illegal? I know it's not recommended, but plenty of people do it and tyre shops are quite happy to lob any old tyre on your car without looking to see what else you've got?Originally posted by JamoIt is actually illegal to have two different tyre treads on the same axle. I know because my Roozer mates pointed it out to me incase i got pulled over about it on my old car.Ex S2 owner, now running around in an A4 Avant quattro...
I think they would prefer it to a bald tyre on the axle! This is worth checking because the roozers ain't always correct about what they think... I'll retract the comment until this is known for sure!
If you've got a different brand spare then you would have to use it, should a puncture befall you. To be honest, if you can run a space saver spare to get home, then using a different tyre of the correct size for the same purpose shouldn't be a problem, even if it is frowned upon for long term use.
I remember running a car through it's MoT with three alloys and one steel wheel (same size tyres but different make) and it was fine!!! That's another story I guess...
As I said before though, it's preferable to fit an equal set on the axle.
It's not better than sex, but it runs it a close second.Comment
ah, yet another case of the visually impaired MOT assessor with shattered glasses, suffering from a recent Mace attack and with a sack tied over his head .... :mischeif:Originally posted by Keeper of The Kitten
__MDC__Comment
