Quick Question
  • RustyNut
    • 1433
    • Home: Zambia Current: United Kingdom
    Quick Question
    Would i be able to fit 8x17" wheels on my car (90Q) with an ET of 48 without having to use spacers?
    Bidding ends tomorrow.
    R.
    Old Stuff Reborn.
  • ~Delta
    • Apr 2005
    • 797
    Russ, will be quite tight at the rear, but yes, they will fit with 225/45x17, or better, 215/40x17.
    Never show a fool a half built house.
    Never underestimate the power of stupid people in large groups.
    Life is like a **** sandwich
    The more bread you have, the less **** you eat
    • Bibby
      • Aug 2004
      • 1043
      Shouldn't be too difficult to get hold of (or fabricate) some spacers if needs be Russ.
      acidtrax
      • porkkis
        • 1994
        ET 48? Probably hits the tie rod ends.
        Siena's first tyre recommendation is way too big.
        • RustyNut
          • 1433
          I didn't think i would be able to get a 45 profile tyre on either without spacing. Presumably i can if the ET was around the 35 - 40 mark?
          Old Stuff Reborn.
            The tyre profile has nothing to do with spacing.
            Spacing is too correct the ET so the wheels wont touch the tie rod ends.
            You'll need 15 or 20mm spacer as ET48 is huge (same size as S8 Alloys)
            The profile affects the overall wheel diameter, profile 45 on 17" wheels is fine, on a 18" profile 45 is too much as the overall wheel diameter is too big and rubs.
            • porkkis
              • 1994
              We're talking 90 q here. 45% 17" would mean max 205 width to keep the diameter small enough.
              • RustyNut
                • 1433
                @Jamo. You're right, they are A8 wheels.
                @Porkkis. Could i not use a 225x45 tyre on a 7.5x17" rim then? This has always confused me as the coupe, i always assumed, has the same running gear as the 90Q sport yet runs this size tyre and rim. I know i have issues with clearance around the arches but this will be dealt with in the not too distant future :mischeif:. I'm running 215x40x17 at the moment without any problems.
                R.
                Old Stuff Reborn.
                • porkkis
                  • 1994
                  Running gear is the same so you have the same clearance at the tie rod end. t89 sedan arches are way narrower than coupe or B4 sedan and that's why you can't use the fat tyres.
                  215/40-17 souds fine to me.
                  • Fat Audi 80
                    • 10547
                    Yep! on a type 89 205 / 40 / 17's were quite tight on a 60mm lowered 80 sport that I owned. There is way less clearance than on a B4....
                    The Perfectionist
                    • RustyNut
                      • 1433
                      Right, last question on this subject as i have to decide on a set of wheels in the next hour or so.
                      What thickness spacer would i need to fit S4 Avus with 225x45x17 tyres and an ET of 45? I'll be fitting B4 front wings so clearence at the front shouldn't be a problem, what about at the back? Unfortunately i cant try them on as i haven't done the hub conversion yet!!
                      Thanks chaps
                      R.
                      Old Stuff Reborn.
                        • 12431
                        10mm
                        it is easier to use S6 wheels like I have since they are already ET35
                        • RustyNut
                          • 1433
                          @Greg S
                          I will eventually use an 18" wheel with the correct offset but will need to do some work on my rear arches before that happens (series 3 90Q). I was thinking 5mm just to be on the safe side as i'm running ET 37 at the mo' And a 215x40 tyre but i've not spaced a wheel before and was just guessing.
                          Old Stuff Reborn.
                          • porkkis
                            • 1994
                            ET38 has proven to be about correct so 7mm spacers will be enough with 215/40 with original narrow arches. 40 could be probably still ok also. I'd try with 5mm first.
