More offset issues!!
  • europeanme
    • Oct 2005
    • 3817
    Judging by an earlier thread the lower the offset the better??....I'm looking at 17"s with an offset of 45, is that going to cause problems?....
    what would be the maximum/minimum ET for 17"/18"?....
    Mike
    ET 45 on 17", let me guess S4 alloys?
    You'd need 10mm spacers, although i think i remember somebody running S4 without spacers
    A better bet (if they are S4's) would be to get the S6 versions which are ET35
    • GandalfS6
      • 332
      • Country: South Africa
      The wheel diameter has nothing to do with what offset you need, the wheel width has. What width are the wheels? On 7.5J's you need offset of between 30 and 37 hence you would need a 10 to 15 mm spacer.
      I think Doug said somewhere you can get away with ET40 on a 8J, so on a 8J a 5 to 10 mm spacer would be perfect.
      1995 Silver S2 (ADU) Coupe
      2006 Porsche 997 Carrera S
      2006 Misano Red RS4
      2004 VW Touareg V8
      2007 Golf Mk1 Race Car
      2004 Mercedes Benz Vito 112CD
        I guess Jamo is playing the wheel guessing game here, but diameter is an important consideration. The general convention, to minimise the possibility of radically changing suspension geometry, when increasing wheel diameter is to decrease the offset.
        The rule of thumb I always use is about 2mm offset reduction for each inch of diameter increase. Dunno the source of that though.
        So assuming that ET37 on our 7.5J rim gives perfect geometry with 16" rims...
        Going to 17" on the same rim width would require ET35
        And going to 18" would require ET33
        Of course when wider wheels are used the ET measurement has to take potential clearance issues into account.
        Paul
        • europeanme
          • Oct 2005
          • 3817
          Well...I will need spacers if I get some 17" with an offset of 45?!?!.....Just to clear soemthing up....A4 alloys (Star) will fit an S2...with A8 front discs??....
          Is there anything tyrewise that I need to be aware??...
          Mike
