Where can I get a stud conversionm for the Coupe? There's a set on Ebay but I just want to check elsewhere too as Ebay usually dissappoints. Any advise etc. is much appreciated.
Stud conversion
Make sure you get the correct length studs for your alloys. Measure your current wheel nuts and use the nearest equivalent - this is because the nuts that screw on to the studs have a closed end (they're "blind" I believe is the technical term?), so you want to make sure you're still getting proper contact and load on the nut.
Clean out the hub threads thoroughly before you put the studs in and I recommend using loctite or similar too. Once in though, they're a fit and forget part and is very useful for locating wheels when putting them back on again...Ex S2 owner, now running around in an A4 Avant quattro...
