I'm no expert, but i know these would need spacers at least 8mm, maybe 10mm thick for my coupe and i'm sure the avant has tighter clearance issues around the rear suspension. I'm sure someone on here will tell you for definate though.
A4's were 5 x 112, but yes they will need spacers as the wheel will sit 10mm further in than your current wheel. On the Avant this will catch the rear leg. You will probably need extended wheel bolts aswell. HTH
Mark
Race Clio RS197
S2 Coupe ABY (Green) - RIP
S2 Coupe ABY (Blue) - Sold
