Hi guys, I recently finished my 2.7t conversion on my 1990 Coupe Quattro 20v 2.3, now I want to install some porsche wheels. I currently have the 4x108 bolt pattern, so I will be converting to 5x112 and getting adapters to 5x130. That way I will have the option of 5x112 for winter wheels.
My question, I want to use Porsche 18" wheels. What width and offset can I use in the front and rear? ALso, how wide do the adapters have to be? What size tires can i use? I currently have H&R lowering springs and Bilstein shocks.
Thanks guys!
Mike
ps, wider is better
Thanks guys!
Mike
ps, wider is better
But you couldnt fit a paper in between there...........
So with the right ET and tire size i suppose 12x18 inch wheels can be possible but that will be a bit extreme!!!
Tires are 255/35 18 Hankook Ventus
