Spacers
  • rotoryboy
    • May 2004
    • 3281
    Spacers
    Was there a better answer for the type used?
    Is it better for the 'HUBCENTRIC' style or 'SPACER and Extended wheel bolt' style?
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
  • rotoryboy
    • May 2004
    • 3281
    Anyone??
    Mark
    Race Clio RS197
    • pastures16
      • 2058
      ive two 5mm spacers if you need a pattern mark
      94 s2 avant
      aoc member 1116
      • rotoryboy
        • May 2004
        • 3281
        Don't need a pattern mate, I'm after an opinion on which type is better/safer etc....
        Mark
        Race Clio RS197
        • PeterS
          • 426
          Mark:
          hubcentric would make more sense, correct? That way the wheel bolts are holding the wheel and spacer to the hub, and the hub is taking the load, vs placing the responsibility of everything on the bolts? No to mention hubcentric ensures that the wheel center is also centered with the hub itself...
          Have heard horror stories of folks with non hubcentric rims having to balance the wheels on the car...
          Peter S
          1990 ErsatzS2 - track toy
          1991 Coupe Quattro
          1991 Coupe Quattro
          1995 S6 Sedan
          1995 S6 Wagon
          • rotoryboy
            • May 2004
            • 3281
            Cheers Peter, That's the info I was after
            Mark
            Race Clio RS197
            • T2Andy
              • 1903
              Had no probs with my hubcentrics they are a better bet in imo i got some pro advice before i used them.
              • WabTheKing
                • May 2004
                • 2567
                dosent matter what the bolts are doing too much, the important bit is the centre as long as the wheel runs true on the hub your laughing
                i have 20mm spacers which i have be bored to suit the hub centre, then i turned a shoulder for the alloy wheel centre to locate on.
                  Mark it all depends on the size of the spacers you are going to use, you only need hub centric spacers when you start going above 8-10 mm spacers, if they are big (15-20mm) you will defo need hubcentric spacers.
                  • rotoryboy
                    • May 2004
                    • 3281
                    Yep, they are 15mm so Hubcentric are ordered
                    Thanks guys
                    Mark
                    Race Clio RS197
                    • rotoryboy
                      • May 2004
                      • 3281
                      Also, I want to put locking wheel bolts on but there doesn't seem to be any long ones available, anyone else done this? don't really want to do a stud conversion just yet. Or do I just do one on each wheel, then get a set of locking wheel nuts?
                      Mark
                      Race Clio RS197
                        Rotoryboy this is the reason i went stud conversion at the end of the day.
                        I couldn't find a locking bolt long enough, i tried the one from mcgard but it's the wrong radius seat it was R14 not R13 which is the Audi Raduis holt size.
                        • rotoryboy
                          • May 2004
                          • 3281
                          so what is the size of the stud I need?
                          Mark
                          Race Clio RS197
                            If you have 15mm spacers then you will need 65mm length studs, i bought 80mm studs and MartinJS kindly cut them down for me
                            • rotoryboy
                              • May 2004
                              • 3281
                              And what model Audi did you use for the locking nuts?
                              Mark
                              Race Clio RS197
