Wheel Judder
  • Azman
    • Sep 2005
    • 3205
    Wheel Judder
    Hi Guys.
    I have had a small problem with wheel judder for a while now and am getting fed up with spending money on balancing etc to sort it out.
    I have spent a good few hours on it today and still have not managed to sort it out or come to a conclusion as to what it may possibly be.
    Right story so far......
    Wheel judder at 60-70mph and onwards so I had them balanced and tracked all round.
    Still happened at the same sort of speed.
    Did the wishbones and sorted the strut bolts out (7a to 3b carriers needed drilling)
    Had it tracked cambered and the wheels balanced.
    Judder now started at 40-45mph and continued.
    Garage said I have small movement on the NEW track rod at the center bush (where they meet in the middle of the car) but it should not affect the tracking.
    All this time I have had a left hand pull if you let go of the wheel at any speed even on right hand camber roads!
    Any guesses so far?
    The story continues....
    Yesterday had the wheels balanced again - judder moved to around 50-60mph.
    Went for a drive this morning - judder moved back to 40-45mph!?!?!
    Just been to have it balance again by a different company (not Kwik fit)
    Took it out for a run judder still there - straight back - swapped front to rear - went for a drive - nearly gone - went back picked up my new tyres as they didn't need to be fitted. Drove home and guess what it's back down there 40-45 again.
    This judder seems to have a mind of its own. I cant and the garage can't put our fingers on it . So I and we are hoping you guys can.
    What has been done recently -
    1. New wishbones and bushes
    2. New RS2 FRAB and bushes
    3. New Drop links
    4. New Ball joints
    5. New Track rods
    6. New Engine
    7. Tracked and cambered by an AUDI specialist
    8. Wheels balance about 7times now
    Thats about it.
    Any Clues Ideas experiences that anyone can draw on for this.
    I have two new tyres ready and waiting just in case it is worth changing some to check if it is the tyres but if they are balanced it shouldnt be a prob should it.
    getting a bit now.
    Please help
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
    • 12431
    possibly drive shaft might cause a judder.
    Also worth checking the the wheel is seating nicely on the hub and there isnt any crap on the two faces.
    • WabTheKing
      • May 2004
      • 2567
      has a balance weight fallen off your wheel,
      have you got an egg shaped wheel?
      either of these can cause this
      • Azman
        • Sep 2005
        • 3205
        Nope nope and nope.
        Wheels were balance again today, all are round Wab and we have checked them. There ies minor deflection by approx 1mm when looking at the wheel rim but I expect that this is normal on such a large wheel as all 4 do it (but it may just be that tehy are dirty and it looks that way)
        Greg How do you mean driveshaft may cause it. It feels like it is defiunatley coming from he wheels as I have the left to right movement of the steering wheel when left alone (well actually it movey your arm and shakes your wrist to bits)
        Dark Grey Avant
        RS2 FARB
        • Azman
          • Sep 2005
          • 3205
          @ Greg again. All faces are clean and clear.
          Dark Grey Avant
          RS2 FARB
            • 12431
            My old Pug 306 got vibration through the steering and car on acceleration it was worse. turned out to be worn driveshafts and wondered if it may be worth checking
            • BRY
              • 3755
              Wheel bearings?
              When were they changed?
              • Azman
                • Sep 2005
                • 3205
                I haven't changed the wheel bearings yet as they came in the hub carriers form the S2
                But all seem fine. No noise, no movement etc.
                At greg, how do you check that?
                Dark Grey Avant
                RS2 FARB
                • Azman
                  • Sep 2005
                  • 3205
                  Anyone think I should replace that track rod again to see if that helps???
                  (starting with the cheapest option first!!!!)
                  Dark Grey Avant
                  RS2 FARB
                  • Azman
                    • Sep 2005
                    • 3205
                    Or perhaps try another set of wheels on it to see if it still happens????
                    Dark Grey Avant
                    RS2 FARB
                    • mcandmar
                      • Apr 2004
                      • 5118
                      brake disks? i've heard of problems like that before with people being unable to stop vibrations. i,ve seen some places that can balance wheels on the car so your balancing disks, cv, drive shaft etc as a complete unit.
                      91CQ20v - Gone to a new home
                      93UR-S4 - The Magic Carpet
                      94S2Bus - The Emerald Express
                      • nothelle300
                        • Dec 2005
                        • 201
                        i had the same problem and replaced all the same bits! turned out to be a buckled wheel although i was told when i had it tracked/balanced that running it on the rear it should make no difference but after trying another set of wheels it does! probably worth trying another set just incase!
                        dean
                        nothelle n300,alcon brakes,sachs suspension kit,lots still to be done!
                        • Azman
                          • Sep 2005
                          • 3205
                          Cheers.
                          Food for thought.
                          It will be a PITA if it is the wheels as they are only 3months old.
                          Dark Grey Avant
                          RS2 FARB
                            • 12431
                            Im not sure how to check it, my dad has been in the trade a long time and told me thats what it was
                            • Keeper of The Kitten
                              • Dec 2003
                              • 2317
                              I had an egg shaped wheel on my 80 and it made no difference at all! Balanced fine and tyre wear was normal, but it was definitely not round!?!!
                              I was thinking brake discs too but I see mcandmar beat me to it! However I think that idea of balancing wheels on the car to balance out everything else is a lot of cr@p to be honest, if it was that bad something really needs fixing!
                              __MDC__
                              Martin Cutting
