will they rub?
  • stevieyid
    • Apr 2005
    • 2251
    will they rub?
    I have just managed to get round to fitting my s4 wheels. I have 10mm spacers as reccomended but it all seems very tight at the back of the car. The tyre width is 225 will this be ok? Anybody else have any rubbing issues running this tyre width?
    Nah, sounds perfect, i run 225 on 18" with no rubbing.
    • stevieyid
      • Apr 2005
      • 2251
      seems very close though between the suspension and the tyre is yours like that
        Yep, it's close on mine as well but no rubbing or scrubbing on the tyres.
        Thats why i wouldn't recommend a wider tyre than 225 as i tried 245 and they hit.
        Forum members have got away with 235's
        • rotoryboy
          • May 2004
          • 3281
          I run 18" 225's with no rubbing
          Mark
          Race Clio RS197
          S2 Coupe ABY (Green) - RIP
          S2 Coupe ABY (Blue) - Sold
          • martinjs
            • 3205
            What make tyres do you have Steve? ie a 225 from one manufacturer can be quite a bit wider or narrower (10mm+) than a 225 from another manufacturer. My current 225 Toyos are noticebly narrower than my old 225 P-Zeros.
            • Azman
              • Sep 2005
              • 3205
              @Stevieyid - I have about 4-5mm clearance off the track rod end, Had the wheels off quite a bit recently and there are no rub marks..
              Dark Grey Avant
              RS2 FARB
              Alloy Subframe Bushes
              • Fat Audi 80
                • 10547
                I am running 245/40/17 on ET35 and rubbing whatsoever....
                P.S. Post some pics!
                Steve
                The Perfectionist
                  Steve
                  what J are you wheels?
                  • Keeper of The Kitten
                    • Dec 2003
                    • 2317
                    Remember that if the suspension is compressed on one side during cornering, the tyre is also being pulled away from the outer wheelarch area by the cornering force. That helps!
                    So, if you're worried about rubbing ...just take the corners faster!!!
                    __MDC__
                    Martin Cutting
                      • Dec 2003
                      • 2317
                      BTW, I am also running 18" with 225/40
                      __MDC__
                      Martin Cutting
                      • Fat Audi 80
                        • 10547
                        8J
                        The Perfectionist
                        • Fat Audi 80
                          • 10547
                          __MDC__
                          'like your thinking!
                          The Perfectionist
                          • rotoryboy
                            • May 2004
                            • 3281
                            Mine are 8.5J
                            Mark
                            Race Clio RS197
                            • SteveH
                              • 4460
                              I've had no issues with 225/40/18 or 235/40/18. However, you could only just fit a fag paper between the track rod end and the tyre with the 235's. The Toyo's I have at the moment are narrower than Goodyear F1's on 8.5J
                              91 Modded 3B
                              14 A6 Avant Black Edition
