urs6 wheel advice
  • lune
    • Jan 2005
    • 109
    urs6 wheel advice
    Hi,
    I've purchased some 18"x8 ET48 later S8 wheels, the tyres currently on the rims are 225 40 18's and on test fitting the fronts catched, so I gather spacers are the way forward. Standard the car runs on 255 40 17's with the rims beng a ET 40. What suggestions/advice do people have as far as spacers/tyre choices go? I have been looking at 255 35 18 or 245 40 18 as I would prefer to keep the cars original wide stance Would this route work and if so what spacers would people recommend? Any advice/experience welcome
    Ben
    You'll need spacers 10 or 15 mm with hub centric locaters on them.
    the tyre choice of 255 35 18 or 245 40 18 will be o.k with the above spacers.
    • Corey
      Banned
      • Sep 2003
      • 2793
      Do not use the 255 on the S6, you will be in tramline city BTDT especially if you have uprated and lowered the suspension.
      I am using 235's on an 8" width rim and she rides very well.
      You will only need an 8mm spacer to bring the wheel back to the correct offset as the factory wheels.
      I assume your original wheels are the same as those fitted to the S6+ and runout urS6? If so do you want to sell them as I have another car that wants a set of those? PM if so
      Corey
      01636 822288
