whilst on the subject, has anyone had any experience with the new Falken FK452 tyre?
Rollin Radius Q's.
As posted above, 90 had 50series tyres, coupe had 60 series. 215/40x18 will work fine on a coupe and give you a close match as the profile is a % of the width, so 40% of 215 is less than 40% of 225 giving you a smaller diameter wheel. With an Audi 90 the figures are way out, approx 7-8% slow speedo reading.
(Coupe) 205/60 15
(Sedan) 205/50 15
http://www.miata.net/garage/tirecalc.html <---very helpfull
Coupe
205/60x15 to 225/40x18 = 1.6% slow speedo
205/60x15 to 215/40x18 = .4% slow speedo
Sedan 90
205/50x15 to 225/40x18 = 8.7% slow speedo
205/50x15 to 215/40x18 = 7.4% slow speedo
205/50x15 to 215/30x18 = 0% change, never seen 30 series tyres to be honest.
Originally posted by New Convertorwhat about reducing the width of the tyre down to 215? Do you think that would make a difference? Did the cq20v come with the same tyres and wheels as its saloon brother?91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
Thanks Mcandmar some usefull stuff there. My question now then is what does the coupe have that enables it to run with the larger profile tyre yet maintain the same relative performance figures as its saloon equivalent? I'm guessing there's different gearing somewhere to enable this? Does anyone know?
RussOld Stuff Reborn.Comment
3rd, 4th and 5th are lower geared on the coupe. 0-60 and 1/4 mile are supposed to be quicker with the 90 so the coupe does suffer with the larger diameter wheels, see here for more specs http://www.20v.org/specs.htm
Gear Coupe Sedan
1st 3.55:1 3.55:1
2nd 2.11:1 2.11:1
3rd 1.43:1 1.30:1
4th 1.03:1 0.94:1
5th 0.84:1 0.77:1
Reverse 3.50:1 3.50:1
Final drive 4.11:1 4.11:1
Originally posted by New ConvertorThanks Mcandmar some usefull stuff there. My question now then is what does the coupe have that enables it to run with the larger profile tyre yet maintain the same relative performance figures as its saloon equivalent? I'm guessing there's different gearing somewhere to enable this? Does anyone know?
Russ91CQ20v - Gone to a new home
