Which P Zero's
  • richslay
    • 153
    Which P Zero's
    Afternoon all,
    Right I may be stupid or else very confused ... i'll let you decide which. Time has come for a new set of shoes and the best offer i have come across at the moment is (god i hate to say it) kwik fit who are doing 25% off when you buy 4, this means zeros are working out at 110 a corner. The question is which ones to go for, obviosuly i want 225/45/Z17 but the pirelli web site lists:
    Zero Rosso
    Zero Asimmetrico
    Zero Direzionale
    Zero Corsa Asimmetrico
    Zero Nero
    Zero Rosso Direzionale
    Zero Corsa Direzionale
    Cheers, Rich
  • Jas11n
    • 5067
    Just to throw a spanner in the works.
    I have P-zero Rosso Asimmetrico.
    Best tyre I've ever tried.
    Have got 225/45/17 on my cup 1 reps, £98 a corner from mytyres.co.uk, fitting was cheap at a fiver from my local specialists.
    I believe Alastair on here (Alg) has P-zero Nero on his RS2, not sure if they are a Direzionale or Asimmetrico.
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • richslay
      • 153
      what does 'Asimmetrico' or 'Direzionale' actual refer to?
      • Fat Audi 80
        • 10547
        Asymetrical tread pattern, i.e. not a mirror image across the centre of the tyre
        Directional i.e. The tyre must be fitted according to the direction arrow (on the correct side of the car)
        Cheers,
        Steve
        The Perfectionist
        • richslay
          • 153
          Does one pattern offer an advantage over the other?
          • Jucca
            • Jul 2006
            • 12
            • Country: Croatia
            I have P Zero's Rosso Assim. in 225/40/18 runing on my S6, they're best tyred ever run, even better then ex. Continental Sport 2
            S6 2.2T, Porsche 996 BT brakes, 18" A8 wheels, Bilstein Sprint, H&R springs, custom muffler, Bonalume BOV
            • richslay
              • 153
              The final choices i seem to have are:
              P ZERO ROSSO Asim 225/45 R17 94W XL
              Pirelli P zero Asim 225/45Z17
              Essentially the choice is between XL and the correct Z rating or W spped but with XL???
              • alg
                • Apr 2004
                • 1160
                I have Pirelli Nero 225/45ZR17 94Y on the RS2 which is the best all round tyre I have used. The 94Y is the key been an increased load rating making it perfect for the heavier avant.
                Rosso are great and I think thats what was on the coupe when Jas bought it. I have only gone to nero due to the load issue and its the newer of the two designs.
                Thats a good deal from kwik-fit just make sure you keep an eye on them while they do the job. They are experts at putting centre caps face down on the floor !!
                Oh and check the tyre pressures after the job with a reliable gauge. Following a recent main dealer (long story) service 31psi all round. After last tyre fitting 41psi all round (I run at 38psi and request this)
                Alastair
                RS2
                • Ski
                  • 2591
                  ahhh now u mention it, I always wondered about this (for no apparent reason).
                  wont the pressure go up once the car load is put onto the typre? as they put pressure into the tyre while the wheel is off the car.
                  Im looking at new tyres for the front, but it seems its a lot more complicated than I thought if i want to go with P-zero's
                  ABY Coupe
                  • blown_vr6
                    • Apr 2005
                    • 406
                    In theory you are supposed to run 'Assimetrico's' on the rear axle and run 'Direzionale' on the front or steering axle of the car.
                    I ran Assimetrico's on my E34 3.8 M5 - great tyre but i often wondered what it would have been like with Direzionale's up front
                    Pete.
                    'If you ain't broke it you ain't trying hard enough'
                    Oh sh*t i broke it
                    94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
                    • richslay
                      • 153
                      Hmm might have to bear that in mind for next time. I am seriously impressed with the tyres though! Living in milton keynes i have been able to test their roundabout handling extensively and it still makes me smile!
