RS2 tyres.
  • charlie
    • 447
    RS2 tyres.
    I have 245/40/17 dunlop sp9000 all round. they are brilliant.
    Does anyone know if they r better than 8000's.
    The only problem is they rub on full lock at low speeds.
    RS2 MTM
  • jubjub
    • Nov 2003
    • 1242
    I have Michelin pilot sports on mine, no issues at all with them. I do not think you can get the original Dunlop tyres that came with the RS....might be wrong tho.....
    • rs2mark
      • Dec 2003
      • 19
      Charlie,
      Are you on the original 7J Porsche CUP wheels?
      If so.. the SP9000 weren't designed to work on a 7J rim.. they are far too wide for that application.
      The SP8000 wheel was specifically designed for the RS2 and as such is the ONLY tyre spec'd to work at 245/40zr17 size on the 7J Cup rim for the specified load index and top speed of the car.
      If you can no longer get SP8000s you should change as soon as you can to a quality sports 225/45zr17 tyre such as the Bridgestone PP S-03, Pirelli P-Zero Rosso or Nero, Michelin Pilot Sport 2 or Dunlop SP9000.
      On the RS2 Yahoo groups list, we've contacted Audi and Dunlop about the issue... Audi haven't a clue and still insist that 245/40zr17 is the right size, because that's what was originally fitted... but they've forgotten that the SP8000, dimensionally, is the ONLY 245 wide tyre that can safely fit a 7J rim.
      We've been informed by the tyre companies to change to the 225/45 tyre as the nearest approximation of the SP8000.
      I personally, currently, have the Michelin Pilot Sport 1s on my RS2.. they work okay - but I will be changing to Bridgestone's S-03 tyre for better wet weather grip when the Michelins are done.
      1994 Audi/Porsche RS2 AVANT.
      • charlie
        • 447
        intresting
        yes i am. Yes they do look fat, like buldging muscles. On dunlops website
        they say the 9000 is the successor of 8000 but provides better wet weather traction and i can vow to that. Their is also a 8080. Im not to
        keen on Michelin, and i dont think 225/45/17 would be appropriate for a car
        like the RS2. That is why porsche tried and tested different combinations &
        brands.
        I think the dunlop sp9000 are brilliant with alot of grip in reserve
        RS2 MTM
        • charlie
          • 447
          Has anyone tried Continentals Sportcontacts on their RS2??? They seem
          to have a good reputation by German tuning houses...
          RS2 MTM
          • Cobstar
            • 98
            Need to get some new tyres for mine. I'd planned to put the Michelin Pilot Sport 2s on but serveral people have recommended the Bridgestone S-03, so now I'm not sure!
            Can anywhere recommend a good tyre place in the South East that will look after my car. And where should I go to get the 4 wheel alignment/tracking done?
            • dan_b
              • Sep 2003
              • 3670
              Re: intresting
              brands.
              There are quite a lot of people on here with modded S2s with more or less power than what the RS2 has, who have various tyre installations.
              I can vouch that 225/45/17 is absoloutely fine, and you'll also find you'll reduce the rubbing issue.
              Various threads in here have discussed the relative merits of different tyres. My personal preference is for the GoodYear F1, very closely followed by the Toyo Proxes T1-S (which should be significantly cheaper too). Both offer excellent wet and dry grip. Michelin are very expensive.
              Don't forget, car manufacturers do deals with the tyre suppliers which gives them the best compromise for them between price and performance. There are better tyres around on the market
              • Doug_RS2
                • 3847
                245 tyres should not be on your original RS2 wheels unless they are the original tyres. They will come off the 7" rim on hard cornering - look on the yahoo RS2 list for more info.
                The RS2 original tyres were especially designed for the RS2 wheels.
                Change them ASAP if you do any spirited driving.
                • charlie
                  • 447
                  dunlops
                  It has been mentioned that Dunlop was comissioned to produce sp8000
                  245/40/17. It is my knowledge that this tyres were not just specific to
                  the RS2 but fitted to other cars with diferent characteristcs.
                  Yes i do know that their cars that produce power close to standard RS2
                  spec, But their other factors to consider namely
                  1) Avant & coupe have different weight distribution
                  2) different rear suspension
                  3) torgue
                  4)different offset etc...etc etc...
                  From close research i have noticed that the sp9000 has a bigger
                  foot print than the sp8000 but yet. at the rim their is an alteration that
                  makes it as narrow as an sp8000.
                  RS2 MTM
                  • Doug_RS2
                    • 3847
                    Dunlop have said do NOT fit any other 245 wide tyre other than the originals to those 7" rims - check the yahoo RS2list - there is correspondance from Audi, and Dunlop on it.
                    Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
                    • Doug_RS2
                      • 3847
                      This is nicked from the Yahoo list:
                      This is the official answer from Dunlop/Goodyear:
                      Dunlop 8000 or any design in 245 40 17 would not be recommended to be fitted to a 7" rim .Although it is doubtful the tyre would come off the rim, uneven tread wear would become apparent (ie in the centre of the tread
                      area) as the tyre would not be sitting corectly on the road surface causing lack of grip & requiring premature replacement. One additional comment , could be a possible Insurance problem should the car be involved in an accident.
                      • charlie
                        • 447
                        pros and cons
                        I've weighed the pros and cons and to my opinion when my
                        tyres wear out, i will still replace them with Dunlops sp 9000
                        but with the 225/45/17 rather than 245/40/17.
                        I've went out for a long spirited drive this weekend to
                        compare Dunlops aganist Coninental conti-sports.
                        Fact:1) Did you know that Dunlop was the ABS pionier when it
                        Came to mateing 4x4 and ABS in the Jenson Interceptor??
                        2)They have been in racing/motorsport and bikes longer than
                        any other manufacturer
                        3) they used to be the sole provider of aeroplanes tyres
                        4) used to and still makes squash ball and shoes for pros
                        For those of you who ever played a serious game of squash
                        would understand that grip reflex is everything)
                        Thanks for feed back guys.
                        RS2 MTM
                        • markrs2
                          • 185
                          I have pushed Audi (UK) and Dunlop on this issue and Audi have now confirmed that no currently produced 245/40/17's are safe to use on 7J rims and Audi now recommend 225/45/17's.
                          • dan_b
                            • Sep 2003
                            • 3670
                            My impression of the Continental SportContacts is that they do last a long time, but don't offer that much grip in all honesty and they SQUEAL like mad!
                            My brother has a set and I don't feel they have enough traction.
                            Seem to be good under braking mind you. It's the tyre squeal that really put me off them.
                            • charlie
                              • 447
                              uniroyal
                              Anyone tried the Uniroyal Rainsport 1
                              RS2 MTM
