Rim/Tyre Advice
  • AbsS2
    • 285
    Rim/Tyre Advice
    Had a High speed tyre blow out on the motorway today(front driver side) , totally shredded tyre inside the rim and out. What will i need to check to make sure car is ok. Obviously the rim will need to be checked i guess, what else should i look to get checked? 4 wheel tracking?
    Coupe
  • GT500
    • Jun 2006
    • 2181
    Best check your drivers seat for brown smelly substance, if found remove seat and jet wash!
    I would just get a pair of new tyres, unless you hit the curb or anything hard, it should be fine. have good look at the steering arm, thats all the flailing tyre could damage.
    Scarey!
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • AbsS2
      • 285
      I know, was a bit scary. Ok thanks for the advice, ill get it checked out. hopefully the rim is still round and not egg shaped.
      Coupe
      • Bibby
        • Aug 2004
        • 1043
        Do you know if you hit something, or did the tyre just fail?
        acidtrax
        • AbsS2
          • 285
          Dont know to be honest, dont even remeber much of what happened, all i remember is pulling over to the hard shoulder. it was a moment.
          Managed a couple of pictures before i got the tyres replaced
          Coupe
          • AbsS2
            • 285
            another
            Coupe
            • AbsS2
              • 285
              last one
              Coupe
              • AbsS2
                • 285
                actually on the second pic looks like that the inside is nearly fully worn. with new tyre its defintely alot better drive. think ill get the tracking done.
                Coupe
