light weight alloys???
  • bazookachicken
    • Jul 2006
    • 157
    @ keeper of the kitten
    cheers for that i'm sure your probably right most would be a mag/alloy. I know BBS and OZ do sets of magnesium wheels which are race use only i know there are problems using them for road use in europe as they won't pass things like the tuv in germany (don't know if you'd have a problem in the uk, I very much doubt anyone would pick it up on an MOT) but they are mega expensive
    @ azman
    best of luck finding what you want, wheels are very subjective but they can really make a car if you get it right
    1995 S2 Avant
    Homefries,
    RS2 intercooler,
    996 monoblocks,
    Koni adjustable shocks,
    H&R springs,
    18" RS6 reps in anthracite.
    150K and running great
    • ericd
      • Nov 2003
      • 1240
      Originally posted by Azman
      Ooooo. Cheapest I have found so far is £175 per wheel (no tyres) anyone know anywhere cheaper?
      found the site I got the SuperL's from, NCTS but found them very good regarding shipping, and very informed, wheels were supplied with relevant TUV paperwork...
      HTH
      • Azman
        • 3205
        ahem, can't understand a word of it...... (me thick you see)
        Dark Grey Avant
        RS2 FARB
        Alloy Subframe Bushes
        • Sweeper
          • 1317
          • Country: Latvia
          I would take Volk TE37 , as they are the lightest you can get but i can't find a proper offset and bolts to fit audi :/
          Vadim.
          New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
          • GandalfS6
            • 332
            • Country: South Africa
            #20
            Originally posted by HPmuirt
            I have never seen any superleggera's on an S2 so would be interested to know what they look like
            Here you go! Mine weigh 7.5kg in 17"s and make a huge difference to handling. In addition they are pretty strong - never had problems running the curbs
            1995 Silver S2 (ADU) Coupe
            2006 Porsche 997 Carrera S
            2006 Misano Red RS4
            2004 VW Touareg V8
            2007 Golf Mk1 Race Car
            2004 Mercedes Benz Vito 112CD
            • robo
              • Aug 2004
              • 2086
              • Home: Poland Current: England
              #21
              Compomotives are good too
              sigpic_________
              Rob
              • s2driveruk
                • 12696
                Looking fantastic can't wait to get mine bolted up - what did you notice specifically in terms of handling improvement? Also, do you happen to remember the bolt length needed for a standard S2 hub?
                David
                1992 3b S2 Coupe
                • A80Avant
                  • 10873
                  • Country: Greece
                  #23
                  which are the porsche 996 wheels that are being reffered as '996'?do they mean the porsche turbo 2 style?The are the lightest 18x8 that porsche makes...interesting...
                  • philip walker
                    • Jul 2005
                    • 254
                    The BBS road range offer some fairly light and strong wheels.
                    The air range are not that suitable for S2 applications, they are lighter, but are aimed at the larger 19" plus size where the weight saving is greater.
                    As suggested above, some very light wheels will not get TUV as they are unreliable in road applications.
                    One of the lightest "reliable" TUV road wheel BBS produce is the RC in a 7.5x17 they are 7.5kg ea. In a 8.5x18 they are 9.35kgs, (18"available from stock @ £699 a set).
                    The motorsport range of wheels are availble with different centers and custom offsets, but these are motorsport wheels, they have no winter protection and need the servicing every few years.
                    Some examples of motorsport wheels available.
                    • GandalfS6
                      • 332
                      #25
                      David
                      The lower unsprung mass makes the handling more accurate - it is easier for the shock and spring to keep the wheel on the ground.
                      The OZs came with their own bolts.
                      2006 Misano Red RS4
                      2004 VW Touareg V8
                        David, PM sent.
                        I didn't notice much difference going from 23kg a corner to 19kg a corner (Dezent to OZ superlegerra) but the acceleration seemed a little crisper. I've not tried them on track so can't comment on at the limit handling.
                        Bolt length is 35mm but as I could only get 33mm these seemed a bit short and would not tighten properly (as with the bolts that caused the problems at the 'ring, I guess my hubs are getting a little tired). I would suggest 40mm instead and am getting myself this lenght.
                        • shark_90
                          • 1475
                          Try Team Dynamics Pro Race 1.2's.
                          1994 Audi S2 Avant - in pieces
                          2006 Skoda Octavia vRS 2.0TFSi - goes fast
                          1985 Audi 90 quattro - is wet
                          Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
                            They weighed the same with Toyo Proxes T1-Rs as my OZs did with Pirelli P-zero Corsa both were 17x8" with 225/45R17 tyres, 19kg give or take a nat's bollok.
                            • shark_90
                              • 1475
                              Cheaper than OZ's I'd imagine?
                                There have been a few offers on the Superlegerras as they're not ultralegerras. I think they're about £150 a wheel but the OZs look a lot better IMO.
