Martin - here is the rear of the RS4 centre cap:
FAO Martinjs: RS4 Centre Caps
And a comparison for those with the ugly replica chrome centrecaps - Get those genuine RS4 centre caps.Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8 -
And a slightly different picture:Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
And, Martin the wheel these caps mount onto:Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
That is close - I will measure the RS4 ones later this weekOriginally posted by martinjs
Doug,
my caps are 149mm in diameter,:mad:
Is this measured? It might be a different diameter to the centre bore of your hub.and the centre bore of the wheel is 52mm:mad: :mad:
If you can't use this to hold the caps on there is another way - cut that bit of the caps off so the caps will sit on your wheel(but won't be held on) - remove a couple of the fake hex heads - mark the positions of these on your alloys. Drill and tap the alloys - fit hex headed bolts to hold the caps on - pretty safe way of holding them on - witht= the added benefit of stopping the opportunist from easily removing the caps to get at the bolts. I was thinking of doing this if they didn't fit securly on my wheels.S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
Just fitted my OEM RS4 centres today and the change is amazing, they look so much better, however mine still seem to sit a tiny bit proud - even with the mod shown on Doug's above. It's only a mm or so but I'd like them to sit as flush as possible
Any BTDT's.......?
cheers
Davidsigpic
1992 3b S2 CoupeComment
