Any issue with fitting Merc fitment wheels to an Audi? They have the same bolt pattern the difference is the centre bore which is larger at about 73mm, I'm assuming this has no adverse effect? or am I missing something.
Your local tyre shop should have centering rings to adapt merc wheels to vag cars. The center bore on mercs is usually 66,6mm so that 73 seems to be the wheels own bore without any ring. Just get 73 to 57 ring and that's it.
Also the offset on a lot of merc wheels is quite high so spacers may be required to get the offset right!
Ragusa Coupe gone!
