Audi s2 coupe tire size 18 inch
  • Audi s2 coupe tire size 18 inch
    Hi
    I have a Audi s2 3b coupe 1992
    I have a set of 8.5x18 et 32 rims
    It's loverd with kw versjon 1
    Whis tire are you recommend
    225. 40.18, or 245. 35.18
    Maybe orther size??
    Sent fra min BLA-L29 via Tapatalk
    depends on tyre brand... I run 235/40 18
      Depends on the tyre, the quoted size is not always comparable
      If it helps know that 245/35 18 Conti Sport Contact fits (just) on the coupe with an 8.5 ET32 rim
        Nice wheels. Looking forward to seeing some photos of them fitted.
        1996 S2 ABY Coupe silver
        2003 S3 8L dolphin grey
        2014 RS4 B8 prism silver
          New paint and polished
            So 225.40.18 is best option?
              225.40 will fit, but depending on the manufacurere *might* look a little stretched on 8.5J - but is a popular size so will be best value
              235.40 will fit perfectly, won't look stretched and is my choice for largest tyre without possibility of clearance issues
              245.35 will fit without clearance issues - depending on manufacturer. not ALL will clear
              It's your choice... which brand are you going for? Maybe someone has experience whether they are on the larger or smaller size of the scale...
                Maybe federal or Falken tires
                  Federal are large. a 245.35 is unlikely to clear
                    Thanks I will check out 235.40.18
                    Do you have any pictures?
                      If you are going with 595 RSR then go with 225/40. They come up wide, even 235/40 has potential clearance issues.
                      I run these on my car with 8.5J x ET32 no problems
                        Is anyone of you used 595 RS-R or 595 RS-RR
                        It's good tires or bad?
                        My normal driv will be cursing og high way and local roads
                        My car is Audi s2 3b coupe
                        With 350hk and 500nm
