Will these wheels fit my 96 s2 coupe?
  • KristianS2
    • May 2016
    • 4
    • Country: Norway
    Hello!
    Fell in love with some wheels i want on my coupe, but not sure if these will fit!
    Specs: RH ZW1, 9X17 Offset 47.. Will lower the car in the future a little aswell, will use spacers if needed.
    Thoughts?
    This gallery has 1 photos.
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    Check the PCD, it should be 5x130 and you will need adapters around 15mm to run those. Being 9J they are too wide for the fronts without fender work, camber etc. The back will fit fine with around 15mm spacer adapters.
    1996 S2 ABY Silver
    • LSG
      • May 2010
      • 898
      I thought that the S2 aby coupé was 5x112. Maybe I'm wrong .
      • robo
        • Aug 2004
        • 2086
        you are not wrong mate, 130 is Rs2
        sigpic_________
        Rob
        • LHD_Kid
          • May 2006
          • 3697
          yes. S2 is 5x112. but Ryan is suggesting the wheels are 5x130 since they look like Porsche fitment.
          I think the centre bore will be different too....
          • LSG
            • May 2010
            • 898
            So I guess what the answer to Kristian S2 is no they won't fit his S2. Although he should be able to find a very similar wheel that would fit. So the hunt begins . Good luck fella. Kind regards Lynn
            • rynaqui
              • Mar 2012
              • 2752
              • Country: Malta
              They can still be fitted using hubcentric adapters. I use these by H&R for over 6 years without issues:
              https://www.ebay.co.uk/itm/H-R15mm-P...gAAOSwNsdXRWKu
              However the front will be a problem as they are 9J, too wide to fit without modifications.
              1996 S2 ABY Silver
