S4 B6 Alloy Spacers
  • Donsider
    • Dec 2009
    • 77
    S4 B6 Alloy Spacers
    Hi,
    Recently purchased S4 B6 18" alloys for my S2 ABY Coupe and looking for some advice.
    What size of spacers required and best supplier.
    Cheers, Mike
    This gallery has 1 photos.
  • Thecrispynoodle
    • Jul 2012
    • 269
    Use this calculator to determine the effect of changing your wheel width and offset. First enter your current wheel width and offset. Then enter your new wheel width and offset. Next click the calculate button. It will show the clearance between the inside of the wheel and the strut housing. It will also show how far the outside of the wheel edge will extend or retract. If you reduce the inner clearance too much or push the wheel out too far, the tire might rub or not fit at all. This calculator is for information purposes only and we do not guarantee fitment based on this calculator alone.
    • M_GORDON
      • Oct 2008
      • 1295
      • Home: Isle of Man Current: Vatican City State
      Not remember the size
      8*18 et48? Same of avus mk1?
      If that's spacer of 15mm
      photobucket SUCKS
