Quick tyre/wheel question
  • dm80
    • Apr 2005
    • 812
    Hoping someone can give me a quick answer on this. I've seen a good set of 17"s I may be interested in: 5 x 112, ET42 with 235/45/17 tyres. Any problems? I've looked up an on-line comparison site, and the difference in overall diameter is ~12mm. I'm curently running stock 3B 5 spokes with 205/55/16's.. Would this offset be ok without the need for spacers? Cheers.
  • bazookachicken
    • Jul 2006
    • 157
    Hi,
    I'd say your going to need at least 5mm spacers to bring the wheels out to the original offset of et37.
    I know the coupe's have a bit more space under the arches than the avants, so you may get away with that. But that seems quite a large tyre for 17's on the s2 and looking at others' posts so you may need to have bigger spacers to bring the tyres away from the suspension.
    I'm currently runing 18x8's et35 with a 225/40 tyre on the avant with no catching along with quite a few others, so the 17's should go under easily once you've got the offset sorted
    1995 S2 Avant
    Homefries,
    RS2 intercooler,
    996 monoblocks,
    Koni adjustable shocks,
    H&R springs,
    18" RS6 reps in anthracite.
    150K and running great
      Need to bring the offset to around 35 so would need ideally 7mm spacers
      Avant or Coupe?
      • dm80
        • Apr 2005
        • 812
        Ok.. cheers folks. Looking to put these on a 3B coupe. What would be the largest offset I'd be looking at without the need for spacers? I agree that a 235/45/17 tyre is a tad large though..
        • Fat Audi 80
          • 10547
          Offset of 37 or less really. I run 245/40/17's on a non lowered car with 8x 17's on ET35.
          You really need to run 225/45/17 OR 245/40/17 not the tyre you have there....
          HTH
          Cheers,
          Steve.
          The Perfectionist
          • Crawford_S2
            • 1555
            Agreed, tyres don't sound quite right and i am running ET20 on the rear of my coupe, lowered with 225/45/17 and no rubbing issues. Fills the arch lovely! et 42 would be too inboard and look weird!
            Ragusa Coupe gone!
            • s2driveruk
              • 12696
              i'm running ET30 on my 18x8's and no rubbing except on violent dips/dives in the road and gunning it a fair bit......wont touch under v hard braking though
              1992 3b S2 Coupe
                10mm spacers tyres are fine not ideal tyre size. 225/45/17 or 245/40/17 are the best match.
                235/45/17 is a 1.6 % variance on stock with speedo reading 60mph and actual speed being 61.1
                Variance should be 1% or less +/-
