Longer wheel bolts
  • MidnightBlueS2
    • Jul 2005
    • 1653
    • Home: United States Current: Belgium
    Longer wheel bolts
    Hi everyone,
    I've searched around quite a bit on the forum but I haven't been able to find an answer to this easy one.
    I'll be fitting my S4 rims (ET45) right after passing thru Belgian Technical Control (MOT) in a week or two and I need to buy some longer wheel bolts as I'll be using 10mm "home made" spacers.
    Can anyone suggest where I can buy 10mm longer bolts ?
    Thanx in advance !
    David
    Midnight Blue S2 - SOLD - 1993 S2 Avant
  • Nuvo
    • Nov 2003
    • 3828
    H&R do them. Maybe you could fire them an email asking for a local supplier?
      • 12431
      I got mine for carnoisseur
      • LOWRAG
        • Apr 2007
        • 56
        I got mine of Flee-bay £1.25 a nolt from a guy called pcs-uk... did the job nicely!!
        • LOWRAG
          • Apr 2007
          • 56
          Yeah thats a Bolt not nOLT..
          • MidnightBlueS2
            • Jul 2005
            • 1653
            Thanx !
            • HPmuirt
              S2Forum April Fool
              • Apr 2005
              • 3014
              Hey David,
              Maybe you could post up your findings as then we'll have a thread for future users to search - quite apart from the fact that I also need 10mm longer bolts for my S8 wheels )
              Cheers n
              Si
              Subtle mods here and there
              2011 A5 3.0 TDi - Lava Grey
              • NoNonsense
                Forum Sponsor
                • Apr 2004
                • 673
                Have you guys ever considered wheel studs and nuts? I know where to get some!
                Joe "NoNonsense"
                axis motorsport
                joe@axismotorsport.com
                  Search for a post re studs by Rotoryboy and do a stud conversion.
                  He has listed the name and email address of a guy that can supply them.
                  Longer bolts suck IMO to fiddly getting the wheel and spacer alligned.
                  • BRY
                    • 3755
                    fireturk on Ebay
                    • AndyP
                      • 6049
                      Havn't I seen that avatar somewhere before?
                      • HPmuirt
                        S2Forum April Fool
                        • Apr 2005
                        • 3014
                        I don't want to do a stud conversion as I plan to run standard 16" wheels for standard road use (for comfort) and then swap to the 18" wheels for fun times :mischeif:
                        Cheers n
                        Si
                        • NoNonsense
                          Forum Sponsor
                          • Apr 2004
                          • 673
                          Cheers n
                          Si
                          Hey Si,
                          This is what I meant by a stud conversion:
                          It makes it much easier to install wheels with or without spacers. For the price that one can get these, they are a great deal!
                          Joe "NoNonsense"
                          axis motorsport
                          • paul rr
                            • Nov 2005
                            • 24
                            bolts
                            hi got my wheel studs from grayston they even do them with spinning tappers so you dont do any damage to your wheel tapers ,you probably got them by now but it might help someone else
