I just bought my S2 Avant. About a couple of weeks a month ago and noticed this constant squeaking noise. It turns out that the inner wheel is rubbing against part of the suspension arm. I have 225x45 R17 at the moment and Audi (in their wisdom) have suggested spacers. My question is what size spacers and where to get them.......... Newbie
I'm confused
Are your wheel bearings ok?
If you look inside the wheel cap area it will tell you size and ET number. Please post these and this will help identify the wheel etc.
DavidComment
Sorry for the delay in getting the info to you. They seem like audi oe's, wheel bearings are okay.
The ET is 45 wheel dimension is 7.5J x 17 H2. I hope this helps. I need to know what size spacers and where to get them from. I tried Halfords but they are 6mm and I am not too sure if these are too much or too little. The wheel arch is quite aways from the wheel itself so I am not too worried about scraping. Any help will be greatly appreciated.Comment
The standard S2 wheels (16*7.5J) have an ET of 37. An ET of 45 moves the wheel 8mm closer to the inside of the car and that causes the scraping. To be safe you would need to get at least a 8mm spacer (effective ET of 37). I am using an ET of 30 on a 7.5J which looks quite good but that would require a 15mm spacer which might put stress on the wheel bearings. I think the best option is to go for a 10mm spacer.1995 Silver S2 (ADU) Coupe
2006 Porsche 997 Carrera S
2006 Misano Red RS4
2004 VW Touareg V8
2007 Golf Mk1 Race Car
2004 Mercedes Benz Vito 112CDComment
Dont forget to buy the appropriate screws for the spacer too. After fitting check whether the outer rim of the tyre scrubs the wheel arch or not. It looks ugly when the tyre exceeds the level of the arch in my opinion. WWW.duw.de shows you different spacer constructions. Spurverbreiterung is the name in German. Good luck.
Gabor
Gabor
96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAFComment
Hello,
IF that is the car i think it is( my old baby) It has original audi
pachino rims which fit perfectly. I never had any problems with them
My original tyres were Pirreli p6000 then went onto Continental
contact Sports Never had a days problem with the car even Fully
loaded.
What make of tyres do you have on their???
They might be 225 but different manufacturers tend to have different
footprints.
Im very intrested to know/help resolve this issue
I hope you are keeping it nice and shiny
RS2 MTMComment
Watch out for cheap wheel spacers. I have 5mm spacers on mine for the wheels to clear on the brakes. They give me no end of hassle, but i think this is due to their universal fitment/design. Custom ones should be fine.sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
Have look at http://www.cromec.com/spacers.htm I have their 10mm spacers and longer bolts on my S6 and now on the S2 (temporarily as I wanted to figure what ET wheels to buy). They are nicely engineered and as they are made in South Africa should be cheap for the guys in the UK and Europe. Don't know about the transport costs but give them a shout.1995 Silver S2 (ADU) Coupe
2006 Misano Red RS4
2004 VW Touareg V8
Charlie; yes it is your old baby. At the moment the squeaking doesn't happen unless the weather is really warm. Audi said it is the wrong size of rims b/c it takes ET35 and mine are ET45 as posted before. Other than that it is a breeze to drive
a bit boring now as I have taken on all comers and basically left them for dust
what was the BHP on it?
A bit dirty now but taking it in for a full pampering on Sat; she deserves itComment
squeeking
are you sure its not the Immaculate black leather seats???
It is a common issue with the back leather seats as others would confirm.
Some leather wax where tthe back seats split and where they lock
upright shoul erradicate the squeek.
As for the rims they were a factory optional extra and are the right
Offset as the centre cap is sunk in and all the bolts are covered.
I confimed this wheels with a certain experrienced Audi Parts manager
(who will remain nameless) and he confirmed this information for me.
They are original Audi Rims and only 35 sets were ever brought into this country and are made by speedline who also make the 16" alloys for S2.
By the way 16" have an offset of 37 and are 7.5 inch wide
17" pachino --------------------------- 45 ---------- 8 inch wide
the rim sits 12.5mm outter but the offset is increased by 8mm to
bring it closer to the car to compensate this.
DO NOT CONFUSE THE REAR OFFSET OF THE COUPE AND THE AVANT.
With avants your limited to how wide and offset you can go.
If in doubt speak to the Exprerts at Vagparts. they will confirm this.
RS2 MTMComment
I've also got this squeeking problem when the weather is warm on my Avant too!
I've just received a new set of rear upper arm bushes from VAGParts. The bushes are worn enough that when the weather is warmer(and drier) that there is no moisture to fill the gap (and stop the squeeking!)
I'll hopefully fit them tomorrow, weather permitting. But if it's too cold, I won't be venturing out ! First road race of the season on Sunday so I don't want to end up cuffed before start
I'll let you know when they're done
Raymond1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
1987 CQ85RS
1994 S2 Avant- Gone
1991 V8 -Gone, but lives on in the TDi and CQ
Fintray Hillclimb - 33.20s
Doune Hillclimb - 55.02s
Forrestburn Hillclimb - 52.61Comment
