et54?
  • Dan_s2_coupe
    • Aug 2006
    • 482
    et54?
    What size spacers will i need 2 fit these on my coupe
  • T2Andy
    • 1903
    15\ 20mm spaces ideally you need 35\37 which is the standard offset dont forget
    the pcd has to be 5\112, and bore size of 57.1 mm
    • Dan_s2_coupe
      • Aug 2006
      • 482
      The wheels are from a new A4 which has the right stud pattern just 20mm is a large spacer to run
