17" Avus
  • dest
    • 4287
    17" Avus
    Sorry if its been asked a million times already... but will 17" Avus from an S3 fit on an S2?
    If not, which ones do I need to look out for?
  • Knight Rider S4
    • 3541
    no as they are 5 x 100 PCD and you need 5 x 112 PCD
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • Knight Rider S4
      • 3541
      these are nice wondered what they would look like on S2
      93 S2 Avant Parting
      91 URQ RR
      02 A4 tdi Avant
      • dest
        • 4287
        OK, thanks
        The car I am looking to buy has 16" Avus, I want to upgrade the brakes, so will need 17s atleast?
        Just trying to work out which ones I can use
        • dest
          • 4287
          http://audi-sport.net/classifieds/sh...uct/675/cat/10
          Someone posted a pic with some on, they do look very nice, and quite tempting!
          • Acidburn
            • 13459
            Depending what brakes you go for some will fit behind the 16 inch avus, from what I remember the 996 brakes do just.
              You can get to potent 314x30 or 323x30 upgrade on 16" Avus. With the latter you might need a few mm of wheel spacer if you have large wheel balance weights in the wrong place. Thats how close it is.
              The 314 upgrade uses some sort of Seat caliper carrier, whereas the 323 uses RS2 carrier. Both upgrades use the Porsche 996 monoblock 4-pot caliper modified to work from its normal 32mm thick disc for this 30mm application.
              Anything bigger than 323mm needs the 17" wheel IMO.
              Paul
              • dest
                • 4287
                Just the info I needed
                Would you say the 323mm setup would be a good enough upgrade to cope with 280bhp which I plan to get (want to do the brakes first after reading about how crap the original setup is!)
                  Yes - the 323x30 with 996 monos is a very good package. Search the forum for more info - these discs come from the Audi A8. It all bolts on if you have all the right parts.
                  Many people have such an upgrade (or the slightly cheaper option with 314x30 using Seat carriers for Brembo calipers) on their 'homefried' cars. This ECU upgrade and the 996 brakes are two of the most cost-effective ways to seriously improve the driveability of the S2 with its understressed engine and insufficient braking power. Uprated ARBs are the next on the list for big improvements in fun, dynamics and handling for very little money.
                  • Matt_D
                    • Dec 2004
                    • 515
                    I have the 314x30 mm URS6 disc setup with Audi TT/Octavia VRS/Audi S3 calipers not sure of carriers as they were already fitted when i bought the car.
                    My car is around the 270bhp mark and these brakes are damn good, i used them in anger the other day to see what they were like as i have never had to brake hard in the 6 months i've owned her and my god i almost head-butted the windscreen.
                    Fit behind the oe 16" avus alloys like a glove.
                    '95 ABY Avant - Sold
                    '98 B5 S4 -MRC400+ = 464ps 741nm
                    • Crawford_S2
                      • 1555
                      I run the 323 with the monoblock calipers. The mounting bracket is a modified Seat cupra r one. Think the RS2 one works with the 314 disc. The calipers need modifying to accept the 30mm disc as they origionally work with 28mm disc on the porsche.
                      I run this setup under 17" wheels with no problems but having tried the 16" spare would say it is a little tight with this setup. There are stacks of threads on here about this, just dig in and get it done!
                      Ragusa Coupe gone!
