18" 8.5 ET 38 Merc / Audi Alloys
  • hiltoa
    • 1060
    • Home: United Nations Current: England
    I've had an alloy work loose (on my old 924) because I'd unknowingly missed the spigot ring off that particular wheel - the wheel should be a close interference fit on the centre bore to prevent lateral forces on the bolts.
    Spigot rings are cheap and necessary. Why not use them?
    Nothing feels fast for long...
    2000 Audi RS4 - Kingfisher Blue ~+~ 2004 Audi Allroad 2.5 Tdi - Ebony Black Pearl
    • dm80
      • Apr 2005
      • 812
      Interference fit? When was the last time anyone had to force on or off a wheel? Wheels are not designed and cast to the very high tolerances needed for such a fit. If they were they would cost a fortune. It's not the space shuttle! The inner bore will have a huge draft angle cast in.
      The point I was trying to make was that it will be a free running fit (which it is), and therefore a relatively large clearance between shaft and bore. Thus prone to shoogle anyway...
        Guys i suggest we leave this dm80 is entitled to his opinion which flys in the face of all the alloy manfacturers.
        The upshot for the original thread I advise and many others do also using a spiggot ring to reduce the centre bore to the correct size.
        There are others who do not believe this is necessary. You have a choice in this matter and you may act upon the information accordling.
        • A1QSHIP
          • Aug 2004
          • 975
          Observations that I can make with over 30 years of removing/installing wheels on cars.
          1) ALL high performance vehicles have hub centered wheels that can be extremely difficult to remove if there has not been any copperslip applied. Many are the times that I have had to use a large plastic deadblow hammer to loosen stuck wheels. The factory clearances tend to be 0.1mm to 0.3mm for MB, Porsche, Audi/VW, BMW.
          2) Not one manufacture of either wheels or automobiles say that it is the function of the wheel bolts to hold the hub and wheel in concentricity.
          3)Wheels ARE designed and manufactured to very high tolerences. Check with Ronal, OZ, BBS, or any reputable wheel manufacturer on their websites for more information.I will bet money that the issue at hand will be discussed at lenghth.
          4) The first item I inspect for when working on a vehicle with a vibration or shimmy is to see if aftermarket wheels are fitted and if so, are the concentric adapters installed. The adapters must be a snug fit to the wheel and the hub to ensure radial runnout is kept within established parameters.
          "Nulla tenaci invia est via"
            #20
            Thanks for that to the man from Lexington... Couldn't of put it better myself.
            Might I also point out that this thread contains the first ever use of the word 'shoogly' in the S2forum - absolutely wonderful. Aint heard that in a long time.
            Gettin back on topic - I can definitely vouch for the centre being a tight fit. I ran RS6 replicas on my S2 for several months without the hub centre caps (long story short). Foolishly I hadn't used any copper grease on the centre face and boy were those feckin wheels seized on tight at the centre. Had to lie on the ground and kick them off the hub face cos I didnt have a plastic mallet that was big enough to shift them.
            • s2 on the way
              • Jul 2004
              • 220
              #21
              well, I've run wheels both ways,,,,
              only time i had a problem was a dumb mistake...
              I forgot to take off the "spiggot ring" when putting back on my stockies and took a turn and it broke off all my lugnuts......(after a roadtrip I had previously taken where lets just say i'm glad it fell off in a neighborhood at the end rather than on the high speed driving that preceeded it), but I didn't even feel any vibration prior...
              but what I'm getting at is I am now going to buy some centric rings for my wheels....
              like its been said "why not?", too cheap not to buy them whether it will cause problems without or not.........
