What spacers to use?
  • MattS2
    • Apr 2006
    • 657
    I need to sort out some spacers to fit 18" A8 alloys and would like some Advice.
    Opinons differ slightly between avant owners some using 10mm on the rear, others using 13mm or 15mm. (all are pretty much using 15mm on the front)
    I have found some 12mm hubcentric spacers..........
    Anybody got any experiences with these? Will they Fit correctly?
    Also, where is the best (ie cheapest ) place to get spacers?
    Matt
    Ex owner of a 1993 Silver Avant - RS2 spec.
    2002 A8 sport 2.8 quattro Sold
    2003 A6 Avant Tdi
    Mk Indy 2.0 pinto circa 160 Bhp
    2004 VW Caddy SDi
    2002 Civic Type R
  • geryS2
    • May 2006
    • 815
    • Home: Belgium Current: Portugal
    I got in a workshop and did 5 mm aluminium spacers, not even with bolts, just pressed when i put back the wheels. No porblem so far and very light !
    Just enough to fit 996 calipers and 17" wheels ( only 3 mm space left between wheel and calipers !)
    S2 's and oldtimers
    • Acidburn
      • 13459
      I'm currently running 19's with 15mm spacers but thats on a coupe, i've seen an avant running 18 inch alloys with no spacers but thats getting a little close to the steering tie rod. What size tyres are you using? Also the avant was lowered as well.
