A4 Avant wheels on a S2
  • Paulm
    • Dec 2003
    • 489
    Will 17" wheels RS4 reps off a A4 2.6 fit my S2.?
    S4 2.7 Twin Turbo, with a few mods
    • 12431
    yes but you have to use spacers.
    A4 is 45mm offset.
    • Paulm
      • Dec 2003
      • 489
      ah, so would i be right in thinking 8mm spacers
      • Markus
        • 184
        Exactly. Using 8 mm spacers will make the offset correct (ET37).
        Although, if you don't mind running the wrong offset you might get away with running ET45. It depends on how wide tyres you're going to mount on the rims. I'm running ET45 on my winter tyres (205/55R16) on 7x16" rims without any clearance issues. The wrong offset might add some load on the wheel bearings, but I like the fact that the wheels sit a bit deeper in the arches in winter.
        In the summer I'm thinking of running ET35.
        Markus
        '94 Kristallsilber-metallic S2 Avant.
        • Paulm
          • Dec 2003
          • 489
          cheers
