Will these 18"s fit with 5x130 adapters
The 8.5 width is whats on my RS2, so they fit,
forget the converter and use RS2 hubs.Rob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8 -
Ok, have got chance of a set of four of these wheels at 8.5 x 18's or another option of two 8.5 x 18's for front and two 9.5 x 18's for rear. (all are 5 x 130 fitment)
Am i right in thinking NONE will fit properly with the 112 to 130 adapters then? And i will NEED to get RS2 hubs for these to fit??
Also, would the 9.5 dished rears fit or would it involve cutting into arches etc...(really cant be arsed with that!)
These will fit fine with adapters provided you get the offset right. Usual offset on the S2 is ET35ish. Porsche fit (which is what these are) usually have a much higher offset ET52 for example. This means they sit much further in towards the centre of the car and you will need a spacer anyway to get them on the S2. So it follows, a 20mm converter from 5x112 to 5x130 would have these sitting just right IMHO.Ok, have got chance of a set of four of these wheels at 8.5 x 18's or another option of two 8.5 x 18's for front and two 9.5 x 18's for rear. (all are 5 x 130 fitment)
You will have to check the offset of the wheels and do your own sums but as long as you aim for the et35 as your final offset including the convertor they should be fine
Not sure about the 9.5 width though
Ragusa Coupe gone!
vw T5 Kombi. In the process of being "ruined"Comment
No chance with 9.5 on the rear, only with arch mods.
52 is the usual off set of the Porsche wheels,as mine are.
H&R converters are fairly expensive, seem to remember £100 plus a pair!
The RS2 hub and disc must space the mouting face alot further out.
Two different ways of getting them on, I know which way I would do it! the less faces mating together the less chance of running out of true.
HTHRob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8Comment
buy two sets and sell the 9.5's to meOk, have got chance of a set of four of these wheels at 8.5 x 18's or another option of two 8.5 x 18's for front and two 9.5 x 18's for rear. (all are 5 x 130 fitment)
Think most would agree that adaptors are not ideal but pretty sure its not as simple as swopping over the hubs to RS2 to get the porsche PCD. Think someone on here in spain did this on a coupe and it took some clever fabrication and lots of extra bits to get it to work. Its a lot more straightforward on an avant i would imagine but we are talking about a coupe here and the rear suspension is totally different.No chance with 9.5 on the rear, only with arch mods.
HTHRagusa Coupe gone!
Try a search for RH ZW1's in 18 inch in 5x112. I also have a set of H&R adapters at home now waiting to try my Porsche splits on at somepoint too. I have the RH ZW1's on my Corrado and TVR.Audi S2 Avant... :D
Corrado VR6... :thumbs:
TVR Chimaera 500... :na:
sigpicComment
just buy four front hubs from an RS2.Think most would agree that adaptors are not ideal but pretty sure its not as simple as swopping over the hubs to RS2 to get the porsche PCD. Think someone on here in spain did this on a coupe and it took some clever fabrication and lots of extra bits to get it to work. Its a lot more straightforward on an avant i would imagine but we are talking about a coupe here and the rear suspension is totally different.Rob..
87 UR 20v ABY
97 S6 Avant
