Will these OZ Mito's (18 x 9,5) fit for S2 coupe ?
that sounds like a good bit of luck...
et 32 will do much better than the 25......7cm isn't much, but with that amount of stretch it should do...
i'm anxious to see anyway
I have booked a reservation to a "rim-doctor" next week.
Ok, it's just a place where the lathe or turn metal parts.
They have the skills to straighten up rims.
When I visited the tire shop last week, staff measured that 2 out of 4
rims had a little alternation when they spinned.
Earlier I supposed that those two rims had the same et and so those rims might have
been installed to the rear of the car. This is not the situation any more.
These li' bit "twisted" rims will be situated either side of the car.
I went to another tire shop and they measured that there is so little alternation
with those two rims that almost nothing can be done that would do them better.
They said that even some cheap tires can cause bigger alternation.
Tomorrows appointment with a rim specialist might then have to be cancelled.
I was a bit anxious yesterday to get some things done, so I made tests:
I bought a Nitro Mors paint remover and AutoGlym Metal Polishing chemicals and made a couple of tests.
So next phase is to wait for the tools to arrive from Germany.
When the rims are unpacked then we can sandblast the parts clean and paint
parts needed.
It was quite easy. Bolts were quite long, longer than I espected.
Inner and outer rim got loose when we slightly banged rims with a hammer that has a rubber end.
There was somekind of a rubbery glue compound that made the rims air tight.
Afterwards glue should also be used to carry out the same mission.
Anyways, now it should be easy to clean, sandblast and grind the parts needed.
I have also been thinking what kind of a color would be perfect for painting the spokes.
This kind of a dark gray is my current vision to be carried out.
I dont have a ready color code for that color, but tell me if you know some color that would be near that shade.
If someone also had a another nice color in mind then tip me. Code for the color would also be nice thing.
My arms and wrists are quite sore after one rim. Only 3 more to go,
and the first patient isn't even ready yet.
Outer rim has been partially polished, but it still needs to be done better.
I have used sandpapers with the values of 400, 800 and 1200 to grind the corrosion,
scrathes and dirt off from the outer rim. After 1200 I used cottoncloth and AutoGlyms
Metal Polish and there can be noticed a kind of a mirror effect after that.
Approximately:
- Outer rims are grinded and polished 90 % with my hands and what's left is done with a drilled, cotton polishing pad attached to it.
- Center piece (spokes) are first treated with paint remover, then grinded with hands and last sandblasted from places where I cant reach with my sausage fingers.
- Inner rims are grinded with a machine and also by hand, 70 % by machine / 30 % by hand.
This phase will surely take time. Well, winter is still to come and theres a long way untill summer.
2/4 are quite ready to be painted. Color is still a mystery.
Outer rims are polished with a metal polishing paste.
Those outer rims still need to be treated with that chemical
couple of times. Bolts and nuts are cleaned with a grinding machine.
I also need new hubs for those rims.
Place called mapsltd.co.uk has couple
of different models that they can supply.
I have also grinded these inner rims, specially from the side which you can see when the tire is installed on it.
It took 5-6 hours to grind one outer rim to get this result.
I used sandpaper with the values of 120, 180, 360, 600, 800 and 1200
and last but not lest I used polishing paste called AutoGlym. It still needs to be treated with that.
Couple of weeks ago arrived 4 of these, HP Raid's short or "hidden" valves.
This is how it looks like when it's installed on a rim.
One of the next things on my "to-do-list" is to find center caps that fit to those rims. This is one of the old center caps, and one taken from behind.
From the caps behind I found the caps part number or etc, M513.
I have made a inquiry to a firm called Maps Ltd and they informed that they
have caps m582 and m595.
If someone has seen proper size caps that would fit, then inform me plz.
Rest of the pictures take this weekend can be found here.
I have also found a nice color that could work with these rims.
As I earlier mentioned, I'm going to paint the spokes.
Something like this 1, 2, 3 is my vision at this moment.
More to come, as soon as my back and my arms are okay.
You've been a busy chappie mylläri. You're certainly putting in the time and effort to get these back to there former glory. They are looking fine.
Where did you get the "HP Raid's", I have a set of 3pc OZ splittties with a standard valve and would like to try these. I'm not sure if I can use them though as my outer lip is 1" or 1.25" if I remember.
You might be able to snage a set of centre caps from eBay. HAve you asked Claus if he has any available?
Personally, I wouldn't go for a gold rim the colour isn't suited to Audis imho. There original colour for these wheels is simply called "OZ Silver". That, or Audi Silver (actual name) would look fantastic on your black Coupe.
I bought those valves from here in Finland, from one of the local tuning crap stores, but those were in sale, 19 € / packet.
You can find those valves also from the manufacturers homepage; http://www.raid-rdi.com/. From the page select; Styling => Valves.
I will contact Claus again at this week and ask for those center caps. Thank for the tip Nuvo.
I'll put in my consideration that silver option also.
Thanks GregS and Casper. My friends think I'm nut because I renovate rims that were made in 1994.
Well, my taste is what it is and I would never install rims that would look like this.
It's also nice to know that there's going to a long time before I see the same looking rims under some
other car in the near future here in Finland.
Btw, Casper you wouldn't have more pictures of that green coupe with those rims ?
