Fitted with 225/40 ZR 18. Standard suspension on UrS6.
Can anyone explain or give me a link explaining ofsets please?
ET = distance from the face of the hub to the centerline of the wheel. For our cars, its negative. ET 45 = further into the wheel well than, say, an ET 40. Putting a spacer on pushes the wheel out (and away from, say, the caliper). An ET 45 wheel with a 5 mm H&R spacer is like an ET 40 wheel.
An ET54 wheel, if that is for real, is really sucked into the wheel well. It would likely rub on the caliper and might even rub the tire on the front springs. Are you sure that its not ET45??
