Just out of interest has anyone else come across this, Goodyear now produce the XL version of the Eagle F1 so maybe they've recognised the problem?
Goodyear F1's 205/55/16
The only comment on F1 is - **** !
Crashed my Merc SLK on them 235/45/17 on the wet !!!!
NOT POSSIBLE TO CONTROL WHEN ON THE WET/PUD ROAD !Vadim.
New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !Comment
I think I have massive problem with my f1's , the car feels like on water now and handling is very bad, at first time after garage meet I thought its the wheel alignment but Saturday I had it done again and the car feels **** , my last dunlop 8080 were very very good well Mark H did like the grip.
Goodyear Eagle F1 = total rubbish
_______
RobLast edited by robo; 8 March 2005, 21:30.sigpic_________
RobComment
what pressure are you running them at? if it feels floaty etc it might be that you have them too hard....?sigpic
1992 3b S2 CoupeComment
thats wierd i ran them until i had 18's an they were excellent..sure your shocks are all ok?sigpic
[QUOTE=Jamo]Just out of interest has anyone else come across this,
i used to use the F1 gsd1 then the 2 with no probs, reccomended them to a friend who by this time could only buy the gsd3, and he also had delaminating problems. he was running them on a cosworth.
i've been using the latest fulda's on my porsche lately. they have improved dramatically in grip/treadwear in the last couple of yearson holiday from S2 ownership
forget the house bills, spend it on the car :rotflmao:Comment
anyone close by that can give you some ideas on potential cause/remedies, does seem wierd, especially at everything is fresh by the looks of it robo - with the exception of the konis (i have bilsteins) your setup is exactly the same as mine.sigpic
I'd have to suspect tyre pressures too - unless your alignment/tracking is hooky, or something's not been screwed back together properly? The last adjective I could think of to describe the F1s in the wet is floaty? I'm using them at 36psi at the moment, what's that in Metric?
Don't forget that wet grip is highly variable: the type of tarmac, the temperature, the depth of water, wear depth of your tread, how long it was since it last rained (ie. how much oily sludge has built up on the tarmac) and your speed are all hugely important factors. A tyre that is good in the wet will still break away quickly if you're tanking it and something changes the friction levels.Ex S2 owner, now running around in an A4 Avant quattro...
I've been using GSD2's and now GSD3's for the last 20k or so and haven't had any issues with them. They seem like a good all rounder.... not had them on the track though and I have heard stories recently of track use killiing them rather quickly even on light motors like mk1 MR2's!!!
I used my GSD3s on the track last summer, at the Bedford Autodrome, and I gave them as much abuse as I could. I boosted the tyre pressures up to 40psi for the track sessions and they were fine. The outside front tyre got rather a lot of hassle and wore out more than the other tyres, but apart from that they stood up to the stress fine.Ex S2 owner, now running around in an A4 Avant quattro...
Maybe too high pressure... Try 2.2 or 2.4 bar !Originally posted by roboI tested them on two different pressures 2.7 bar and 2.9 bar no difference what so ever.
Feels very floaty , I made big mistake
_____
RobPaul Nugent
Just done a conversion:
2.7 bar is 40psi
2.9 bar is 42psi
I'm not surprised you're finding them floaty at that pressure: for normal road use I'd consider that way too high.
I'm running at 2.48 Bar (36psi), which is a nice compromise between ride and turn in, and no float. I have previously been running them at 34psi (2.34 Bar).
On my old 80Sport, with 195/55/15s, if I ran the tyres at 24psi, I got loads of grip, but heavier-than-an-elephant steering. 32psi was too much: really light twitchy steering, floaty ride and no traction. 26psi seemed about right for that car, a good compromise between all those factors.Ex S2 owner, now running around in an A4 Avant quattro...
