Will these fit ok?
  • dest
    • 4287
    Will these fit ok?
    Can anyone confirm if these will fit an avant with no need for spacers or rubbing?
    4x 7.5x17" AUDI RS4 Style Alloy Wheels & Tyres x4
    fitted with 215/45x17
    PCD 5x100 / 112 - ET35
  • Fat Audi 80
    • 10547
    Sounds fine to me.
    *Waits for an Avant driver to confim*
    The Perfectionist
      i'd say yes, but I recon you want some spacers and/or a lower offset to improve the look... ET35 on a 7.5J won't "fill" the arches, should fit fine
      • Knight Rider S4
        • 3541
        They will fit no problem as there is only 2mm difference on the ET from standard
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • Skull
          • 3506
          • Country: Slovenia
          1cm spacer on rear, and at least 2cm in front
          Audi Quattro WR
          • Acidburn
            • 13459
            Lol thought you was going for s8's mate?
            I'd have to say you'd probably want spacers to fill the arches.
            • dest
              • 4287
              Cant afford S8's
              Pretty sure I will get the RS4 reps, and some spacers if needed!
              • Big Lee M
                • 2571
                mine more than likely will be up for sale a few weeks after christmas if theyt are i'll PM you or you PM me if you are intrested? they are only a few months old
                Just some finishing touches to do now
                • dest
                  • 4287
                  PM sent
                  • Keith
                    • Sep 2003
                    • 84
                    • Country: France
                    @dest :
                    Carreful with these if you use RS2 or Porsche calipers, they may touch the inside part of the wheel !
                    I had these on my car, and there was less than 1mm free between caliper and wheel (mounted with 5mm spacer on caliper with 314mm discs) A friend of mine used the same whells with 304 discs without using sapcers on calipers..... the calipers touched the wheel !!!!
                    No problem with OEM calipers !!
