Why do my back wheels stick further out than the front?
  • shark_90
    • 1475
    It is definitely not down to the offset of the wheels, as all the offsets are the same
    I don't know what the Coupe's like but looking at my Avant, the rear wheels definitely appear to sit further out towards the edge of the arch than the fronts. Why is this? Surely that's got to be factor no.1 when it comes to understeer??
    Would I see any handling improvement by spacing the front wheels out slightly to match the rear (presuming the rears are sitting further out and it's not just my eyes playing tricks on me..)?
    1994 Audi S2 Avant - in pieces
    2006 Skoda Octavia vRS 2.0TFSi - goes fast
    1985 Audi 90 quattro - is wet
    Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
  • dest
    • 4287
    I keep wondering this too!
    I guess spacers on the front is the simple answer to solve it
    • alg
      • Apr 2004
      • 1160
      Different rear suspension than coupe............read better with wider track hence appearance.
      Makes the handling more stable IMHO having had both with konis.
      Better solution to understeer is a thicker rear ARB and/or firmer rear damper setting. My konis are stiffer at the back with 1o negative toe in at front on standard spec alignment which makes for a perfectly balanced road car IMHO
      Alastair
      RS2
      • MattS2
        • Apr 2006
        • 657
        Have a look on S2central for info Ben.
        Here
        As previously said, the avant has different rear suspension to the coupe.
        I've gone 10mm wider on the front with spacers but haven't noticed any change in the handling. It looks better though.
        Matt.
        Ex owner of a 1993 Silver Avant - RS2 spec.
        2002 A8 sport 2.8 quattro Sold
        2003 A6 Avant Tdi
        Mk Indy 2.0 pinto circa 160 Bhp
        2004 VW Caddy SDi
        2002 Civic Type R
        • shlab
          • Feb 2008
          • 29
          • Home: Romania Current: United States
          i noticed this on my 92 V8 as well. I think its a visual effect because if you look at the rear wheels from the front of the car, there is more rubber exposed as the bottom end of the car tucks underneath towards the underbody therefore exposing a good chunk of rubber. thats what i think,.
          Emy
          1990 Audi Coupe Quattro | Atlanta, Georgia, USA
          Audi S2 - "Don't try to hunt what you can't kill"
          • Skull
            • 3506
            • Country: Slovenia
            on my limo, 8x17 wheels offset 37, and the rear pair is almost out of the archs, front miss almost an inch each...
            Audi Quattro WR
