Split rims
  • robo
    • Aug 2004
    • 2086
    Split rims
    This may be very daft question please dont laugh.
    Split rim is this means that you can adjust the offset to your requirements? If yes how far can this be adjusted?
    thx
    sigpic_________
    Rob
  • s2driveruk
    • 12696
    i just thought it meant that the face and the rim were separate items held together with bolts rather than the whole item being cast as one????
    1992 3b S2 Coupe
    • Rusty
      • 18953
      It's so that you can change the width of the wheel by fitting different sized sections together. This does affect the offset because that is measured from the centreline of the wheel.
      2 piece wheels have the main section and centres as one ans the lips are separate.
      3 piece have the lips, centres and main sections all separate.
      To alter the rim size you need to buy new bits.
      HTH
      • BRY
        • 3755
        But due to the above you can position the centre on the outside or the inside of the mounting face which changes the offset.
        Not all wheels can be assembled like this but some splitties can.
        Offset change is about 10mm, depends on the wheel
        • robo
          • Aug 2004
          • 2086
          The reason I’m asking is I need another set of boots for road use, wet use, and these toyos 888 not very good for wet. Andy is selling mates bbs's so I thought bingo, if I only could adjust them to 0 offset or less.
          Thx for your replies.
          sigpic_________
          Rob
          • BRY
            • 3755
            They won't do what I said.
            The centres on the BBS LMs are flat and you can do it with them
