painted wheels
  • s2_southwest
    • Oct 2004
    • 823
    painted wheels
    Just a little piccie of my rs6's painted up.
    Thought the picture might be easier in the post rather than link to facebook
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
  • s2driveruk
    • 12696
    Yeah they are looking gooooooood!
    1992 3b S2 Coupe
    • Acidburn
      • 13459
      Nice wheels, sent you a comment about them
      • s2_southwest
        • Oct 2004
        • 823
        got that comment acid burn. They are 8x18s, car is lowered on H&R springs, they say thats about 35mm iirc, might be slightly less then that
        • Acidburn
          • 13459
          Cool, are yours spaced out at all? mines slightly on the front, can't wait to see mine lowered.
          • s2_southwest
            • Oct 2004
            • 823
            not spaced yet but i am going to! lowering it makes it look so much better
            • s2driveruk
              • 12696
              yeah mines on H&R's sure the drop was more like 40mm, looks the dogs
              1992 3b S2 Coupe
              • s2_southwest
                • Oct 2004
                • 823
                You could well be right there, im sure it was at least 35. 35-40 is a good drop, can still get over most bumps and i dont get any rubbing at all even with the 18s!!!
                • s2driveruk
                  • 12696
                  Are those RS6's an ET35 offset? my ET30 RS4 reps rub if i hit a wallow on a smooth road but never under heavy braking etc
                  1992 3b S2 Coupe
                  • Acidburn
                    • 13459
                    I'm not sure the et on mine, its not lowered yet but it does catch on the drivers side wing under hard cornering but not the passenger side I have also found that if I have brand new tyres on the rear they rub on the bottom of the suspension cups so I might space the rear out soon, the arches are getting rolled soon.
                    • Rusty
                      • 18953
                      They look reallyt good, what colour did you use?
                      • AndersS2
                        • Sep 2005
                        • 1364
                        • Home: Norway
                        Liking the White vs dark grey colour!
                        makes your car badass
                        Anders - S2 Avant Clubsport - 8pots or die!
                        • s2_southwest
                          • Oct 2004
                          • 823
                          its a vauxhall colour, i have the code somewere, will look it out.
                          • andyg plym
                            • Nov 2006
                            • 4646
                            they look so much better painted,im not one for 5 spokes but painted look good and id stick them on my pimp mobile
