Avus II; what spacers
  • Edlers
    • Jan 2006
    • 43
    • Country: Denmark
    Hi
    So, my "wheelthread" changes its form for the next issue....
    I need to find the right size and quality of hub-spacers. I know some of you guys have given me some information regarding the subject, but........
    Are theese any good; http://cgi.ebay.de/ws/eBayISAPI.dll?...MEWA:IT&ih=012 ?? Or which brand could be recommended ?
    I would like my new wheels to have a perfect "BMW-style" (sorry... ) fit in the arches, especially the frontwheels since they are so "grandpa" narrow original.
    Wheels: 8Jx18" ET 48 S4 Avus II - 225/40R18
    Hub-spacers front: ?? mm
    Hub-spacers rear: ?? mm
    I have been told that the thickness of the spacer should be a few mm thicker than the stick-out of the spigot on the hub, in order for the spacer and wheel to fit safely. Therefor 10 mm could be problematic ??
    Well, if any of you guys could help me fill out the questionmarks, I would much appreciate it.
    OOOO....Lord of the rings....OOOO
  • BRY
    • 3755
    They would work, but they are heavy as they are made of steel. Alloy ones are lighter and do the same job. Like these
    • Edlers
      • Jan 2006
      • 43
      • Country: Denmark
      How about theese H&R ones ?? Are they safe with the nut embedded in the aluminium ?
      Size front ?
      Size rear ?
      • BRY
        • 3755
        15mm fronts
        13mm rears
        IIRC
        • Edlers
          • Jan 2006
          • 43
          • Country: Denmark
          THANX..... I suppose 13 & 15 is in regard of the "BMW-style" (sorry again ) and the wheel meassures ....?
          • BRY
            • 3755
            The rear of the avant has later / wider suspension than the front. The body is straight from front to back.
            So, for the wheels to sit in the same place in the arches you need thicker spacers on the front.
            • mcandmar
              • Apr 2004
              • 5118
              Looking for the same myself, the H&R Trak kit look quality, e.g. http://www.optionimports.com/30255571.html
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • T2Andy
                • 1903
                S8 Wheels 15mm spaces allround
                • Edlers
                  • Jan 2006
                  • 43
                  • Country: Denmark
                  Wonderful Coupé, look good wearing those S4's ..... But since the Avants have different rear suspension, i guess its 13 mm rear and 15 mm front as Bry says, to obtain the nice wide arch fit....??
                  • BRY
                    • 3755
                    They are late S8s on Andy's car.
                    • DarrenM
                      • Aug 2007
                      • 1227
                      I want some 15mm for rear of my coupe, currently running 10mm,needs a bit more tho. Those "S4's" are actually mk2 S8's as well btw!
                      • Edlers
                        • Jan 2006
                        • 43
                        • Country: Denmark
                        Hi there again
                        I've just discovered that the ET on my new rims are 45, and not 48 as I wrote earlyer.
                        Would 15 mm front and 10 mm rear hubspacers still be a good choise ??
                        • Edlers
                          • Jan 2006
                          • 43
                          • Country: Denmark
                          Anyone...?? Please. I'm just about to order....
                          • Edlers
                            • Jan 2006
                            • 43
                            • Country: Denmark
                            Noone really ..... :-(
