What offset do you run?
  • shark_90
    • 1475
    I currently have 2 sets of wheels, one set are 17" ET35 which are fine, the others are ET45 and I run 15mm spacer at the front and 10mm spacer at the back.
    I'm looking at some new wheels and I can't decide how far I dare go with the offset. The current ET45s with 15mm spacer (i.e. ET30) rub on the arches but only when the suspension dips a long way.
    Another question - on an Avant the rears have a wider track than the front. I haven't driven on the track with the ET30 front ET35 rear setup so I don't know what it's like handling wise, but is the consensus that it's better to try and neutralize the offset difference (i,e, use a slightly wider offset on the front) or run the same offset all round?
    Opinions appreciated as always
    1994 Audi S2 Avant - in pieces
    2006 Skoda Octavia vRS 2.0TFSi - goes fast
    1985 Audi 90 quattro - is wet
    Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
    Offset and fitment depends heavily on the width of the wheel as well, a 9J ET20 will not fit the same in the arch as a 6.5J ET20 as the offset is the difference between the mounting surface and the centre line of the wheel cross-section
    • s2driveruk
      • 12696
      on 8jx18 i think ET30 is the furthest outboard you can go without fouling the arches.....my RS4 reps are that and only ever scuffed twice on lateral long yumps on the motorway. If you run a green top mount rather than blue you can probably avoid that scrub too
      1992 3b S2 Coupe
      • Rusty
        • 18953
        Both my 17s are ET35 but the OZs seem to stick out further than Dezents even though they are both 8J and have the same 225 tyres on them... Not sure that the OZs don't rub but there's no evidence on the tyre so I've guess they don't.
        If you get the arches rolled then you can go a bit more but ET35 might be more common so easier to find...
        • Crawford_S2
          • 1555
          Running 8J 17" ET20 on the back, no fouling issues.
          Ragusa Coupe gone!
          • Skull
            • 3506
            • Country: Slovenia
            7x17 et 25 on limo, rears at the limit, front still need 2cm spacers.
            Audi Quattro WR
            • s2 on the way
              • Jul 2004
              • 220
              I've got 17x8.5's et 20.... they are fine for now with 215's (rub free), but when I get new 245/55's we'll see, its gonna be really close
              • K Simmonds
                • Dec 2007
                • 7637
                I run 7 X 17 et 40 rims all round with 8 mm spacers on the rear and 5 mm spacers up front. I have no problems with arch fouling and the wheels fill the arches nicely. I don't get any tram lining either which can be a problem when using low offsets.
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
