Just woundering what offset either way is the limit? I have a offset of 35 and it fills the arches right just woundering if 48 would fit and look stupid?i don't think they would but then again i know nothing about this:
easy rule of thumb, the higher the number than ET37 (stock S2 offset), the more inboard they run, i.e. closer to the calipers........lower the number the more outboard they run, i.e. closer to the edge of the wheel arch
Also rule of thumb as you increase the wheel size the offset must decrease
i.e 16 = 37 17=36 18=35
But you will find by default 35 is a good offset for 16,17 or 18" alloys and for 19" 30 is better
