Tyre numpty needs help!!...
  • europeanme
    • Oct 2005
    • 3817
    Having purchased a very set of S8's I am know looking at tyres....after searching on the forum, I have decided to post the question....
    what size tyres will fit these 'babies'?...without fouling the suspension...I have 15mm spacers ready to go on....
    any help is really appreciated...
    Mike
  • s2driveruk
    • 12696
    235 or maybe 245 would get on the rim, not sure on the offset so only *think* they will fit ok....
    1992 3b S2 Coupe
    • Rusty
      • 18953
      The 15mm spacers take you from ET48 to ET33. I can't say I've ever found 225 lacking in grip so some 225/40R18s would be top of my list. Go wider if you want but I can't say you'll notive any difference other than a lighter wallet.
      • europeanme
        • Oct 2005
        • 3817
        cheers for this......
        • Rusty
          • 18953
          Oh, and the new Eage F1 gets the Forum vote at the mo, there are a few fans of this tyre, me included but it ain't cheap.
          • S2_Dave
            • Aug 2005
            • 456
            If you're going with Eagle F1s, stick with 225/40/18 as the price goes up sharply if you want a different size.
            David
            '91 3B S2 Coupe
              I concurr with Andy here... 225/40 or 225/45 on the 18 should be plenty enough.
              You could dial out some understeer however with wider fronts if you wish, but you'll need to play with profiles to keep rolling radius same (ish) as rears.
              245 is max recommended width on 8J but some tyres might squeeze on at 255 if you push your luck.
              • dest
                • 4287
                As above, mine are 225/40, sorry I forgot to reply to your pm about this mate!
                With the H&R's on, 15mm spacers and S8's, Ive only had them rub twice on the rear.
                Both times were with 2 adults in the back on a very bumpy B road, apart from that its been fine
                • s2driveruk
                  • 12696
                  too true about the price hike from a 225 to a 245.....at least £20 a corner
                  1992 3b S2 Coupe
