re-drilling aluminum rims
  • rs2coupe
    • Oct 2004
    • 1782
    • Home: Trinidad and Tobago Current: United States
    Sound advice regarding re-drilling alloy rims. Is it a bad idea? With my 5x130 hub changeover I am giving up some nice choice of 5x112 rims I already have. My thoughts are to weld the old 112mm holes and re-drill to 130mm. I am more concerned about safety than anything else if it's plausible especially on the track.
    Cheers mis amigos,
    _Anton
  • Acidburn
    • 13459
    I think you can buy adapters from H&R to do this, I know you can do it the other way round i.e. 5x112 to 5x130 as I know someone who has it done.
    Jas11n was thinking about doing this but I think he changed his mind about it.
    • K Simmonds
      • Dec 2007
      • 7637
      Adaptors will ****** up the offset of the wheels, Unless you are already running at least 15mm spacers all round, ie ET 48 wheels. Never seen bolt holes welded up but I have seen wheels re drilled, they were four stud however.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • WabTheKing
        • May 2004
        • 2567
        i wouldnt weld them, only safe way you could so them is tapping them, studding them and then re drilling them, kinda like stictching them, im running hubaddaptors on the rear for 5x130 and rs2 front hubs
        • WabTheKing
          • May 2004
          • 2567
          sorry drunk angain speeling out the window again
          • rs2coupe
            • Oct 2004
            • 1782
            at wab...
            regarding the adapter option can I run et48 5x112 rims on a 5x130 converted Coupe?
            Cheers mis amigos,
            _Anton
            • Rusty
              • 18953
              Adaptors are between 15 & 20mm thick so ET48 becomes ET33 to ET28 so pretty much spot on for an 8" rim / 225 tyre.
              • rs2coupe
                • Oct 2004
                • 1782
                Thanks Andy... mmm S8 avus:mischeif:
                Cheers mis amigos,
                _Anton
                • ridgeracer
                  • Sep 2005
                  • 189
                  • Country: Norway
                  In Norway and Sweden they do this :
                  They bore the new boltsircle with a larger diameter wich cover the old boltsircle ( coned holes ) and press in steel coned cylinders.
                  Or my way: weld the old holes in the hubs and redrill in wanted new boltcircle ( i changed from 5-130 to 5-120 to accept BBs challenge 9.5X19 )
                  96 RS2
                  94 urS4
                  02 ALLROAD
                  • rs2coupe
                    • Oct 2004
                    • 1782
                    I like your idea but what are your thoughts on the strength after welding in the holes and re-drilling new bolt circles? Does forge aluminum lose it's strength after welding and tapping?
                    Cheers mis amigos,
                    _Anton
                    • ridgeracer
                      • Sep 2005
                      • 189
                      • Country: Norway
                      I know about several cars who drives with wheels with changed boltsircles and Ive never heard about any problems.
                      the new holes in the hubs were not drilled in the same place as the old ones so i dont see any problem in doing this.
                      96 RS2
                      94 urS4
                      02 ALLROAD
                      • Rusty
                        • 18953
                        I think this is all down to what level of risk you are willing to accept. I would not be happy with it but then I'm a pessimistic engineer
                        • Fat Audi 80
                          • 10547
                          I totally agree with Andy, I am also a pessimistic engineer and would definitely NOT re drill alloy wheels....
                          Cheers,
                          Steve.
                          The Perfectionist
                          • Rusty
                            • 18953
                            pessimistic engineers unite!
                            • ridgeracer
                              • Sep 2005
                              • 189
                              • Country: Norway
                              TS racing in Norway has a silver A3 with re drilled BBS CH 10x19. this car is used hard on track. before that they had a purple/pink A4 with the same kind of wheels, and those cars have been used for years on different trackdays. I guess that speaks for us who recomend re drilling wheels
                              96 RS2
                              94 urS4
                              02 ALLROAD
