RS2 radius nuts on Audi radius rims ?
    I've converted my hubs to studs and wish to keep it that way.
    I have a set of hefty 8x18 RS6 reps with tapered nuts currently attached.
    To save weight, improve the ride quality (and avoid looking like just another Audi running cheap RS6 reps) I'm going back to Avus rims.
    Trouble is the Avus rims require radius seat nuts and I can't find any so far - is there a specialist supplier for these somewhere I can't find so far ?
    I can find superlight RS2 nuts and locknuts with the right thread very easily - sure they aren't cheap but they'll be good as Porsche spec items.
    So can the Porsche radius nuts work on Audi wheels ?
    Maybe I would need to get the rims machined to accept the Porsche radius... That only works if I can find a solution by removing metal - and not so much that I weaken the wheel.
    Anyone got any dimensions of S2 bolts versus RS2 nuts - or photos to give me a visual on this little problem ?
    Paul
  • Al Wyn
    • Nov 2006
    • 3746
    Paul ive got a few RS2 wheel nuts up for grabs... if you need them pm me
    S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
      Could I even borrow five of them pretty please - just to see what fitment is like with no mods to the wheel ?
      I know they are expensive boogers from new - superlite - I've found a few places that supply a range of light and steel nuts (and lockers) for Porsche wheels. Why the hell couldnt Audi & Porsche just do the same thing ?
      I'll post them back after a trial fitment or two...
      Interestingly I might have found some open ended M14x1.5 nuts with the right Audi radius - recommended for sporting applications when its wise to see how much thread is engaged. I won't waste time here with links until I get feedback from them on suitability for Audi.
      • Al Wyn
        • Nov 2006
        • 3746
        Only £6 each new x 5 for each wheel x the 4 wheels and yes they are very very light
        • adamw
          • Dec 2005
          • 348
          • Country: Shetland Islands
          about 19gms
          cheeRS adam
          RS2+
            Demon Tweeks
              Thanks to Mr Laser - I got a handful of these exotic nuts - and they are indeed shockingly light... On a dry fit of a bare Avus they seem to nip up just fine - whereas you know with a tapered nut that something isn't right.
              Its hard to get a good photo of the subtle visual difference between the Audi & Porsche radius seat.
              I sprayed some black paint into a couple of the seats on the wheel to see how much purchase the two types were getting... I need to dig up the photos from my phone via another machine...
              You can see how the Porsche nut engages nicely on the outer edge of the seat with the paint wiped off, but when you compare to the Audi bolt - the entire seat is wiped clean of paint.
              So I need to decide if I feel comfortable with the grip the Porsche sized nuts will have versus Audi items - versus some machine work to the wheels to accomodate the Porsche seat radius - it looks like there is more than enough meat on the wheel.
              Any other thoughts on this ?
              PS - ain't tried demon tweeks yet.
                The manufacturer that DT use is called Graystone (sp.) so might be worth checking their website to see what they make. What about VW Transporter nuts?
                  The DT website only lists M12 and tapered seat applications - keich... WIll try graystone directly...
                  As for transporter nuts - I scoured the family album but couldn't find anything but wheel bolts on the Transporter - maybe that was a red herring or its only applicable to one model year or something weird ?
                  • Nuvo
                    • Nov 2003
                    • 3828
                    Paul,
                    Wouldn't it be easier to machine the Porsche nuts to the Audi radius? I take it you'd need to add metal rather than machine it off to make this work? I haven't worded this well, I hope you follow what I mean.
                      Ahah - looks like http://www.graystonengineering.com/wheelnutmenu.htm is a possibility with Part Number SN436 right at the bottom of the page...
                      Nice one Andy :beer
                      I like the thought of the open ended nuts.
                      I'd be pretty happy with those and a set of Porsche / RS2 locking nuts if I'm not getting 100% perfect seating.
                        And so the pics to prove the point...
                        Firstly various nuts and bolts compared visually. From the left then -
                        1 - A 60 degree tapered bolt for aftermarket wheels
                        2 - A stock Audi radius bolt
                        3 - An exotic RS2 radius nut - note the 19mm head versus 17mm
                          COmparing the Porsche / RS2 radius to the Audi radius... The look the same dimensionally to my eye but there is just so much more on the RS2 nut i.e the seat is fatter on the same radius.
                          Does indeed look like if you machined the RS2 seats to same width as Audi that it would be a fine fit.
                            I sprayed some black paint into one seat on an Avus rim and torqued up the Porsche / RS2 nut. It felt good enough but did seem to protude much more due to its larger dimension - heres the proof - just under half of the seat on the wheel gets to grips with the RS2 nut - far from ideal...
                              Versus the same seat (paint still wet) after fitting and removing a factory wheel bolt - all of the seat grips !
                              So I'm going to order up these M14x1.5 radius nuts from Graystone and verifiy they are the business with studs on factory wheels.
                              Then for a locking solution I think its going to be factory or aftermarket Porsche / RS2 nuts which I might need to get machined for a completely perfect seating - though I'd be less worried with four other good nuts/bolts in place.
                              I have run factory radius locking bolts on tapered aftermarket wheels for many years without problems - the radius gets some grip on a tapered seat - and all the normal nuts are tapered of course.... You cannot run tapered nuts in radius seats though.
