With my Coupe running better now I think it is time to get on the track again
I need to look at setting my wheel alignment up for the track. Does anybody have a favourite wheel alignment setting for track use? I assume about 1 degree of negative camber front and rear, but anything else i.t.o. other settings relative to the stock setting that works?
You help will be greatly appreciated!
I need to look at setting my wheel alignment up for the track. Does anybody have a favourite wheel alignment setting for track use? I assume about 1 degree of negative camber front and rear, but anything else i.t.o. other settings relative to the stock setting that works?You help will be greatly appreciated!
