fitting 114pdc wheels to an s2 112pcd hubs?
  • S2Ian
    • Oct 2006
    • 310
    there is nothing wrong with a well manufactured bolt with a variable collar, its a mith that they are unsafe, the aftermarket motor trade use them every day!
    Also you will find that some car manufacturers used bolts/nuts with a 60 degree taper and a collar as well as the flat seating arangment that had a washer built in.
    i have used them on my car which has had a set of buddy club P1 wheels that only came in 5 x 114.3. the wheels were machined out to accept a m14 x 1.5 bolt with a collar, then i used a 10mm hubcentric spacer which fits like a glove in the back of the wheel & then 20 of said bolt to attach the wheels to the car, i have found it a most effective method to achive what i wanted.
    the wheels have never come loose, sure i check them on a regular basis as a part of the checks i do on the car & never found them to be lose.
    if i had found wobbly bolts or variable bolts to be a problem with my own car i would never reccomend them as a fitting option to other peoples cars as my line of work centers around the aftermarket!
    if you decide not to go with this option you could always go with a set of hubcentric spacers that addapt your pcd from 5x112 up to 5x114.3 you might find though that you will have to make your own spacers, but try first speaking to people such as RH, H&R or Eibach!
    hope this is usefull to you.
    regards
    S2 Coupe, ruby red, 95 - Slight mods
    A4 Tdi avant, many greens, 97 - Workhorse
    • Fat Audi 80
      • 10547
      Originally posted by anton
      i dont see any problem with re-drilling the hubs, it will be just as safe as standard as long as it is done properly....only issue is cost.
      Ant
      Nothing wrong with correctly redrilled hubs, (new holes obviously not oval ones!). I think it is the dodgy "wobble bolts" that are worrying people, and quite rightly. Who would use those?
      Cheers,
      Steve.
      The Perfectionist
      • Keeper of The Kitten
        • Dec 2003
        • 2317
        In fairness, as long as the wheel is seated on a concentric spigot on the hub, the only thing the bolts do (other than hold the wheel on!) is transmit the drive or braking loads from the hub ...and it is very common practice on race cars to use oval holes on brake disc bells. Of course the narrow dimension is orientated radially so the drive is a snug fit.
        If there is any looseness such that the wheel can be rotated on the hub slightly, I wouldn't want to use it.
        Martin Cutting
        • anton
          • Jan 2005
          • 802
          i'd say the real problem here is the added shear stress your putting in the bolt as the force is no longer central on the main shaft of the bolt, ok not as much as the normal load but still a substantial amount i would have thought.....and the bolts need top be tight....dont forget the force of breaking is far greater than that off acceleration and that comes from the friction between the surfaces of the hub and wheel on the disc.
          i think it is ok for shows and POSSIBLY light/low performance cars. but on an S2 i'd say a definate no go!!! and i assume you want these wheels as they are light, ie better performance so you'll be putting high strain on these parts....
          Ant
          91' Coupe quattro 20v - project
          KW V2s and other goodies
          now gone
          03' BMW 330CI - Sold
          08' A5 Coupe 3.0l tdi quattro - Sold
          57' BMW 525d M Sport Touring
          • S2Ian
            • Oct 2006
            • 310
            #20
            anton i agree on your valid points that if you are using these wheels for track use you wouldnt want a bolt with a collar beacuse of the added extreem stresses caused through cornering, braking and the like. but i dont belive they are unsuitable for use on the road.
            but if you use the road like a track :mischeif: and your unsure then yes stear clear, i dotn believe they are unsave for the average user, im v happy with the results & did consider the possiblitites before bolting them on the car.
            It depends on how you drive your car and what you like to use it for as to whether variable bolts (wobbly) would suit you.
            • Jas11n
              • 5067
              Concept in Belgium make some adapters, but they are expensive at €160 a pair
              Link
              2001 Avus Silver B5 RS4.
              1995 S2 Coupe - sold (sniff)
              • anton
                • Jan 2005
                • 802
                i guess these bolts are quite over-engineered as standared so perhaps there is no issue for normal road use but i would still be very cautious.
                Ant
                now gone
