These wheels were on my list as well when concidering to replace the RHs ones.I have to say,unless they are porsche original(which means BBS are the manufacturer for this type) the replicas are very very heavy! about 12Kg each and if you add another 9Kg at most the tyres,you end up with almost 45Kg heavier.You do notice the difference only when you actually use something lighter.
Getting spacers is not a tough job,and i cannot understand why things went wrong with polishing frenchman,it should be rather straightforward.
As far as looks,the are much better than the turbo design 1 that i had(the black ones),and also if you look at the thread
what wheels? ) on page one there is an RS2 with them on 18inch.However porsche original wheels are very very expensive,which is why i ended up with the Veloce ones 3.6 and perfect fit!!!
