Conversion Washers - Any BTDTs ?
    Just found this site in a search for Grayston SN17BR (M14 x 1.5 RADIUS nuts)
    And realised they carry some handy looking conversion washers like SW24 which can convert 60 degree tapered bolts/nuts onto a radius wheel... Giving wider choice of aftermarket locks and lightweight nuts for Audi wheel applications.
    I was going to change onto winter rubber this weekend and remembered I hadn't got the radius type studs for the Avus wheels. They are so cheap I reckon I'll ge a set and test them out - unless anyone else has horror stories ?
  • europeanme
    • Oct 2005
    • 3817
    the closest thing I had was a set of stainless custom made bolts that had a set of washers made to match the rad in the wheel and it worked a treat.....I know it is not exactly the same but the principal is there....
    if they are cheap, give it a go...nowt to loose...
