A stunning revelation...S2 hubs.
  • Flat on my back
    • Jan 2007
    • 2449
    Just been staring at my S2 avant hubs, a front and rear split from the carriers...as you do...
    Although not the same as seen in the picture...you could fit the rears in the front carriers to get a +20mm (10mm each side) increase in wheel track width.
    Anybody done this?
    Off to read my Bentley for the track dims on coupes and sedans...
    Doh...scrub that got the hubs the wrong way round...should have labelled them...
    Carlos.
  • twoqu
    • Sep 2003
    • 3103
    Hi!
    Can you get me the approximate dimension from where the wheel bearing race sits against the hub and the hub mounting face for the wheel. Ta!
    Should have added just for the rear one!
    • Flat on my back
      • Jan 2007
      • 2449
      Looks to be about 26.8mm
      Hope it's this one.
      Carlos.
      • twoqu
        • Sep 2003
        • 3103
        Yep! Many thanks!
        • Skull
          • 3506
          • Country: Slovenia
          flat: so would the rears work in front? if that would work it would be great.
          Audi Quattro WR
          • Flat on my back
            • Jan 2007
            • 2449
            Noooooo...was me gatting it completely round my a....e!
            A rear will fit, but it will move the disc mounting surface 10mm further inboard on each side. So, if you can find a set of discs that move the braking surface outward 10mm this will cancel things out.
            You will still need 10mm spacers on each side to bring the wheel track distance back to standard.
            Think it will work but a lot of hassle...
            HTH.
            Carlos.
              So based on this, you can fit front hubs to the rear and get +10mm track? :mischeif:
              • Flat on my back
                • Jan 2007
                • 2449
                To align the new disc 10mm further out, and back in line with the original caliper you'll need Brembo discs no. 09.5734.10 (S2 disc no. 09.5724.20)
                This is all comparing S2 parts, what discs are you running, i need dimensions to be more confident.
                The Brembo website catalogue gives you dimensions for comparison.
                Hope its not too confusing...
                Carlos.
                • Flat on my back
                  • Jan 2007
                  • 2449
                  Quite likely...remember all my parts are avant. Not seen a coupe rear hub in the flesh...got one?
                  Carlos.
                  • Josh-stateside
                    • 741
                    this won't work because the cv are different sizes. S2 hubs = 82mm cv joints and drive shafts. Rears are 75mm. The only way hubs work is if they match the drive shafts. the inside splines are different.
                    • Skull
                      • 3506
                      • Country: Slovenia
                      avant rears are 82...
                      Audi Quattro WR
